[April 06] Volumio (2.390-2018-03-27) ROCK64 | [April 06] Q4OS (2.4-r3) PINE A64(+) Pinebook | [Jan 06] Arch Linux (20171225-1) PINE A64(+) Pinebook A64-LTS/SOPINE | [Jan 04] Linux (0.5.15-136) ROCK64 | [Jan 04] Android (20171204) ROCK64 | [Dec 22] Stretch Mate (0.5.15-136-20171222) ROCK64 | [Dec 21] openHAB 2 (v1.4) PINE A64(+)
Project Inspiration | Get Started | IRC Logs | Forum Rules/Policy
RESET and PWR_ON pins
I'd like to be able to provide physical switches to reset and power up/down individual SOPINE modules in the clusterboard and I'm guessing that the RESET and PWR_ON pins on the 20 pin header next to each module could be used for this?
I would guess that tying RESET to GND would reset the associated SOPINE module, and that tying PWR_ON to VCC will boot-up the module, but these are just guesses Smile
I'm sifting through the various documentation to determine exactly what these do and how to use them, but if any of you happen to know if these pins can be used for these purposes (and how) please share Smile
(04-13-2018, 10:33 AM)jgullickson Wrote: I'd like to be able to provide physical switches to reset and power up/down individual SOPINE modules in the clusterboard and I'm guessing that the RESET and PWR_ON pins on the 20 pin header next to each module could be used for this?
yes, the RESET and POWER pins on the 20 pins header can be used.
Cool, thanks for confirming that @tllim.
Could you provide any additional details?  What I'm looking for what the pins should be connected to (PWR, GND, etc.) in order to trigger reset, power up/down, etc.
Thanks!
Thanks!
The Clusterboard 20 pins header definition just provied on PINE64 wiki page and here is the link: http://files.pine64.org/doc/clusterboard...header.jpg
