Smart TV -media player with 5.1 Dolby and/or DTS /AC3
Hello. I would like to now if is possible to have on Rock 64 (4gb) 5.1 output in movies (Dolby, DTS or AC3 pass trough) on a regular 5.1  audio system only with RCA inputs (like Creative). I am having in mind two solutions. Install Android on the board and:
1.add the extension   and use an additionally device like this conected with optical cable.
2.use this device and transmit the audio via HDMI and after to the speakers.
Is it feasible? If yes which will be better?
(01-06-2018, 01:24 PM)robix12 Wrote: Hello. I would like to now if is possible to have on Rock 64 (4gb) 5.1 output in movies (Dolby, DTS or AC3 pass trough) on a regular 5.1  audio system only with RCA inputs (like Creative). I am having in mind two solutions. Install Android on the board and:
1. ROCK64 STEREO AUDIO board Don't know support from RKMC / LibreElec playback yet  .
Just know ROCK64 STEREO AUDIO board  support  Volumio now.
Update :  Rock64 STEREO AUDIO board only work STEREO (2.0) by ES9023p , don't thinking about this , you will waste your time and money
2. HDMI To RCA 5.1 box
Rock64 is hdmi 2.0a output
Have you know this HDMI To RCA 5.1 box not is a HDMI 2.0a input /output ?
This box  is HDMI Input Resolution: Up to 3840x2160@30Hz;4096x2160@30Hz.
If you buy it , maybe you will downgrade output HDMI 1.4a  to 5.1 RCA  , can't read hdmi 4k 60Hz output ,  but ROCK64  can playback 4k 60hz HDR10/HLG video file from 1080p 60Hz TV / 4K 30Hz TV.
And don't worry  this box is work  , because i used HDMI to SPIDF box  (Dolby, DTS or AC3 pass trough) .
You need to go Android or RKMC setting output sound  from hdmi is work.
You need to go Android setting output display  hdmi resolution 1920x1080 60hz / 3840x2160 30Hz
* Note * (You need to two hdmi cable )
If I am wrong please correct my content , thank !
1. Use Pine64 Running Ubuntu 16.04 Web Server ( LAMP )
2. Use Pine64 Running Official Android 6  for Media player
3. Use Pine64 Running Volumio Digital Audio Player
thanks for the answer but is still not clear for me. which solution to follow? 1 or 2?
(01-07-2018, 02:11 AM)robix12 Wrote: thanks for the answer but is still not clear for me. which solution to follow? 1 or 2?
Sorry about my english  , you only to buy hdmi to rca , because rock audio board may not can work RKMC and LibreElec video playback software
OK Joe, its very clear now. I will buy the hdmi to 5.1 box. thanks a lot!
(01-07-2018, 07:37 AM)robix12 Wrote: OK Joe, its very clear now. I will buy the hdmi to 5.1 box. thanks a lot!
Smile  enjoy your ROCK64
This is my HDMI to SPDIF box you can see the box inside have chip to transform sound   , this box from my bedroom to use.
And living room i direct to use hdmi output
[Image: 2.png]
[Image: 1.png]
thanks joe i will place the orders for all the stuff.
  R64 media server Timelord47 0 3,322 05-09-2019, 04:19 PM
Last Post: Timelord47
  My other media board packed it in. Help? thatguyyouknowtheone 0 2,999 01-15-2019, 06:55 PM
Last Post: thatguyyouknowtheone
  4K Player post2skumar@gmail.com 7 14,537 12-03-2017, 12:08 PM
Last Post: Sauromayne
