Industrial applications
Hello ,
I am curious about whether the pine A64+ can be used to create industrial device for data monitoring using serial and TCP/IP modbus communication. Is there any such product in market implementing the Pine A64+ ? Thank you.
(10-15-2017, 11:03 PM)g_magic Wrote: I am curious about whether the pine A64+ can be used to create industrial device for data monitoring using serial and TCP/IP modbus communication. Is there any such product in market implementing the Pine A64+ ? Thank you.
The answer of course is yes.
...  come visit on the irc channel and talk with maya;  she is there most days ( European time zones ).  She is a department head of an engineering firm in the process of building a field unit designed around the Pine-- specifically the sopine module.  They are planning to open-source parts of the project;  you might be able to get some good insights from her.
Shy
