Ir receiver
How can I get the damn IR receiver working? Can it be done in android?
(10-09-2017, 04:21 AM)w.otter Wrote: How can I get the damn IR receiver working? Can it be done in android?
Works out of the box with the IR remote  available in the store
With what remote? I haven't been able to get a programmable remote to work. It would help to know the pair/sync numbers associated with the receiver.
I ended up purchasing one of these, instead: https://www.amazon.com/dp/B00Z81U3YY/ref...B00KF9IVKC
Here is the PINE64 remote control code table and also use in ROCK64: http://files.pine64.org/doc/Pine%20A64%2...t-logo.jpg
(10-11-2017, 12:30 AM)tllim Wrote: Here is the PINE64 remote control code table and also use in ROCK64: http://files.pine64.org/doc/Pine%20A64%2...t-logo.jpg
That's what I've been looking for, thanks. Time to set this thing up with my Logitech Harmony remote so I can have one remote to rule them all!
Thanks, tllim!
can anybody tell me how in android is possible setup or scan ir codes with integrated ir sensor. I have rock64 board
