found fix for man
So straight out of the case the pinebook wouldn't show any man pages.  It would say page ?/? like it didn't have any data for anything.
I tried loading or re-loading man-db (sudo apt install man-db) with no difference.  Even a "sudo mandb -c" looked promising with 6000+ pages added but nothing would display.  Finally a "sudo apt --reinstall install groff groff-base" fixed it.
I was close when I tried to install nroff and troff.  I kept getting a troff failed message sometime after I did a man.  When I went into console mode it would say man ended with code 2 and nroff would be at the end of the long string of commands above it.
I guess I need to do that kernel upgrade to get rid of the flickering and flashing/tearing of the screen.  I thought apt upgrade would do that but I read somewhere here that it doesn't update boot or kernel.
Exclamation
Nice work !
Thank you.
Shy
  Ethernet not found. error during boot Surehand53 1 5,276 07-24-2019, 05:00 AM
Last Post: ObviousHobbit
