Rock64 charger availability
I just received my Rock64 and I thought I had also ordered a power adapter (UK), but I didn't and checking my order I didn't actually order one.  If I buy one through the store here then the shipping from China will cost more than the product itself. However I can't a single 3.5mm barrel charger (5V, 3A) in online in the UK, it seems to be a very strange type of power cable.
Does anyone have idea where to get one in the UK?
I have found some USB to 3.5mm barrel charger, so if I found a USB plug which is 5v 3A would that work?
You have two possible options.
You could go with an adapter like this (best quality one I found on a cursory search of amazon.co.uk), or you could go with the USB-to-3.5mm cable.
Whatever you go with, make sure its connector is 3.5x1.35mm, and the cable is fairly thick. Thin cables will cause voltage drop and seemingly random issues under load.
Unless you live in West London - buy me a pint I give you a charger Wink
How did you find that on amazon I spent ages trying to find the correct size plug which was also 3A (not 2A)
Thanks Luke, il try the amazon cable but if that doesn’t work then I’ll take you up on the offer (I’m in north London so it’s a bit of a trek to west london)
(08-18-2017, 04:57 AM)jon889 Wrote: How did you find that on amazon I spent ages trying to find the correct size plug which was also 3A (not 2A)
Fire219 used clever search parameters "power+adapter+5v+3a+3.5mm" Smile
  DeskPi case alternative for ROCK64 v1k699 2 12,314 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 3,872 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,012 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 46,059 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 10,413 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 4,402 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 20,443 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 5,956 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 8,323 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 7,289 06-08-2022, 12:44 AM
Last Post: Zoz
