08-04-2017, 08:09 PM
Oakbook!
08-04-2017, 08:57 PM
(This post was last modified: 08-05-2017, 12:08 AM by MarkHaysHarris777.)
ok...
... now compare to this: Also looks familiar ? Actually, many many vendors use the same case design because the injection plastic design process is so expensive; it can cost as much as $100K dollars for each new opening in a particular case design; so is extremely expensive as development cost, and case designs are often shared. This particular case design has been used by several vendors.
marcushh777
please join us for a chat @ irc.pine64.xyz:6667 or ssl irc.pine64.xyz:6697 ( I regret that I am not able to respond to personal messages; let's meet on irc! )
08-05-2017, 12:47 AM
(08-04-2017, 08:09 PM)combs Wrote: https://www.cloudmedia.com/?page_id=2371 There is a reason for that! If you look a bit closer, you'll realise that that 'our' TL Lim is the founder of Cloud Media, and YC Yeoh is the general manager. Hence there will be a lot of R&D resources shared between the two companies, which are in essense just two different brands used for the different target markets. pine64 does the more developer-y stuff, where as cloud media is the more end user-y stuff.
08-05-2017, 06:32 AM
(08-05-2017, 12:47 AM)pfeerick Wrote:(08-04-2017, 08:09 PM)combs Wrote: https://www.cloudmedia.com/?page_id=2371 Cool, that makes sense. thanks for the explanation! |
