Battery status on panel?
Hi guys I'm using the armbian image on my pine with Lcd and ts working
With a 6000mah battery diy it's any chance to get the battery stats on the panel?
I know that it works on Android
But can't find a way to make it work on Linus help pla
Thanks!
Sent from my Moto G (4) using Tapatalk
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
See there:
https://forum.pine64.org/showthread.php?...ery+status
[url=https://forum.pine64.org/showthread.php?tid=1404&highlight=Battery+status][/url]
apt-get -y install xfce4-power-manager-plugins
then go to applications menu, settings, panel
items tab, press +, and add power management plugin
i have installed the xfce powe manager plugins
it recognize when i plug or unplug the cable and shows charging and discharging notifications even but never shows up the actual value of the battery so every time i unplug it it says battery too low, how to pointer the configuration files of the plugin to work with the pine battery values on the /sys/class/power/battery ( or something like that ) directory ??
By. Zoidiano0!
Installed:
Netbeans 8.1
  +LTS/SOPINE how to change for init status of gpio chun jong rock 7 16,219 03-28-2018, 06:57 PM
Last Post: chun jong rock
