ir remote howto figure out which keys are being pressed?
hey all
i bought a ir remote which works fine except for the fact i cannot get up the delete [context menu] menu
how do i figure out which keys are being pressed with this remote in order to modify the keymap file for kodi to my liking...
is there a program that can tell what is the keycode this remote uses if i press a key?
thanks for any help..
If you boot a Linux image, you can use 'evtest' to check what the IR receiver sees...
  Pine64 Remote and Remix VAAviator 3 6,964 06-09-2016, 07:25 PM
