I am using syncthing on many different devices without any problems. On PINE64 with Ubuntu Xenial and longsleep's kernel I installed syncthing from https://github.com/syncthing/syncthing/r....21.tar.gz It start and I can connect to other devices but the actual syncing is not starting. Is this an ethernet problem or could it be something else? How do I go about finding the cause and fixing it? Are there people here that got it working and if so, how? Thanks
How to get syncthing to actually start syncing
01-26-2017, 06:00 AM
Well, its a bit hard to tell without a log. Regarding your ethernet question; have you updated the kernel ?
Pipe to logger and come back with what you have - create this script (suggest you set it to start at boot): Code: #!/bin/sh
Ah, found the error. The web GUI was available to all on the network and that disabled syncing. I will discuss this in syncthing to get a more specific warning about this. Thanks nevertheless for trying to help me.
(01-26-2017, 06:53 AM)Pander Wrote: Ah, found the error. The web GUI was available to all on the network and that disabled syncing. I will discuss this in syncthing to get a more specific warning about this. Thanks nevertheless for trying to help me. Nope, wasn't the error, but at least it works now. Perhaps that it upgraded itself fixed it.
01-26-2017, 08:21 AM
Ah, it was the upgrade, see https://forum.syncthing.net/t/syncing-di...all/9101/4 so I encourage all that would like to use syncthing and had troubles before, now all should be fine.
Unable to start Pine | Topgun505 | 16 | 24,154 |
11-13-2016, 12:01 AM Last Post: Gnx |
