OpenMediaVault (PINE A64(+)) 4.13.10 [Nov 21] | OpenMediaVault (A64-LTS / SOPINE) 4.13.10 [Nov 21] | Q4OS (PINE A64(+)) 2.4-r1 [Nov 10] | Volumio (ROCK64) 2.299 [Oct 30] | Q4OS (Pinebook) 2.4-r1 [Oct 30] | DietPi (ROCK64) v156 [Oct 24] | Armbian - Xenial Desktop (Pinebook) 5.34 [Oct 24] | motionEyeOS (PINE A64(+)) 20171003 [Oct 23] | Android Images (ROCK64) 20171012 [Oct 23]
Getting Started | Visit the WIKI | IRC Logs | Forum Rules/Policy
[SOLVED]Problem Compiling modules: Recipe | kernel-headers not found
Greetings
I found a little problem and thanks to the indications of @longsleep I was able to solve this problem.
I am writing this post in case someone stepped with this problem too.
The Issue
I was trying to compile some module for the kernel but I was not able to
because make complained about not finding the recipe.
The issue was produced because /lib/modules/(VERSION)/build was missing
The Soultion
The quickfix was to create a symlink called /lib/modules/(VERSION)/build  to /usr/src/linux-headers(VERSION)
The origin of the bug is that the pine64_update_kernel.sh is not updated.
You can find the last version in longsleep github
Extra information
I am using the image Debian Base (3.10.102 BSP 2) Jul 17 2016
from https://www.pine64.pro/downloads/#Debian-Linux
I hope this may help someone
Possibly Related Threads...
  OMV base on Debian jessie Root Problem ayamy 3 151 09-03-2017, 09:21 PM
Question Debian Jessie with 4.x.y kernel and complete hardware support? Spark 2 936 04-24-2017, 09:56 PM
Last Post: Spark
  Debian Jessie Images (3.10.102 BSP Kernel) New Release lenny.raposo-pine64.pro 257 73,148 04-12-2017, 10:54 AM
Last Post: dontpostalot
  Adding a missing kernel module spz2k 8 811 01-10-2017, 06:22 AM
Last Post: xalius
  NIC not visible after kernel update xleon 1 480 11-15-2016, 05:23 PM
Last Post: xleon
  Synergy dependency problem S265 3 526 10-27-2016, 12:44 PM
Last Post: TidBits
  LCD Monitor resolution problem S265 2 838 09-21-2016, 05:19 AM
Last Post: S265
  Debian Jessie (4.7.0-rc1 Kernel) Images fire219 4 2,983 07-20-2016, 02:36 PM
Last Post: umiddelb
  i2c-bus kernel modules robertvaldimarsson 15 1,068 06-07-2016, 01:48 PM
Last Post: robertvaldimarsson
  How to install modules into system? MicroDiery 6 663 05-27-2016, 06:44 PM
Last Post: JamesHarris
