GPU Overclocking
Is it possible to overlock the GPU on Android? I need more power for ePSXe but not so much. Also, with Android Marshmallow there will be more graphics performances?
No possibility of overclock the gpu?
Overclocking is a bad idead;  not supported, and prone to difficulties ( don't do it ).
Tongue
(11-16-2016, 09:46 AM)NNittola Wrote: No possibility of overclock the gpu?
I only use it with Android 7, Mali is clocked with 408 MHz by default but on all my OrangePi it runs with 600 MHz. Increasing 'normal_freq' is easy and without risk since GPU cores will also be downclocked when A64 starts to overheat.
https://github.com/ayufan-pine64/device-...4-plus.dts
Use a heatsink!
Users browsing this thread:
