17 minutes ago
I live in an older house in Nashville and I am thinking about replacing the recirculating range hood over my electric stove with a ducted under-cabinet model. The kitchen is small and the stove sits against an interior wall, so the duct run would be short but would have to turn out through the wall rather than go up through the roof. The model I keep coming back to is the TAZPI 15S-E30. I found its specs and some discussion of it online, so at this point I am working only from third-party information. My main concern is makeup air: the house is fairly tight, and I do not want a stronger hood pulling against the furnace or water heater. I also cannot tell whether a 30-inch width will clear the cabinets cleanly without trimming. Has anyone here installed a ducted under-cabinet hood in a tight older home? Did you need to add a makeup air path, and how did you handle the wall exit?
