Power button not being ignored by init
Hello, my pinepone is booting into pmOS with sxmo on sway, and the power button is acting literally: i.e. immediately it is pressed once, shutdown is initiated.
What I'm expecting to happen is that it will work as bound to Return in sxmo menus, that it will wake from suspend, or turn on the display when off, etc. (as it was doing previously).
I guess that I am missing some config to tell init to ignore the power button. Can someone please let me know e.g. which package would set that up on the pinephone? I reckon I might have accidentally deleted something in the fix of a messed up apk world.
(05-17-2026, 05:08 PM)forestcreature Wrote: Hello, my pinepone is booting into pmOS with sxmo on sway, and the power button is acting literally: i.e. immediately it is pressed once, shutdown is initiated.
Hello. I ran into a similar issue after an APK upgrade. On an OpenRC-based system, editing /etc/elogind/logind.conf helped in my case:
HandlePowerKey=ignore
HandleSuspendKey=ignore
HandleLidSwitch=ignore
Then restart elogind:
sudo rc-service elogind restart
Hope this helps someone else as well.
  Phosh beta 10, no send button on Chatty? Rainer 0 3,096 05-24-2021, 08:17 AM
Last Post: Rainer
  How to make volume and power buttons do things koampapapa 3 8,634 07-31-2020, 12:49 PM
Last Post: Boern
