If your USB-C port is flakey...
I was having problems with my Pinephone's USB-C charging port. I tried a few different cables but they were all making intermittent connections, if the phone was moved around at all power could be lost and then would reconnect making the phone boot up.
I do have a spare USB board but before doing surgery on the phone I sprayed some DeoxIT contact cleaner into the port and plugged/unplugged a USB cable several times. After doing this the port is working fine! Even directly wiggling the connector doesn't break the connection.
The Pinephone's USB port is open to dirt and debris and over the years apparently enough got in there to affect the connection. So if you're having problems with your USB connection this is something to try before swapping out the board.
*** EDIT *** Oops, I meant to post this in the regular Pinephone board, not the Pro board! Though I expect this info applies to both models.
