Quartz64b pcie help needed
Hi all. Is anyone using the Pcie connector on the back of the Quartz64b ? I am revisiting this board after some considerable time. Lets say it has been in storage. Anyway I would like to make use of it again. Which brings me to the Pcie part, Is this used with a flat cable? or is a M.2 card able to be plugged directly into this ? I cannot find much information about it. Has anyone seen a compatible hat that may be used with this connector ? Your comments/experience may point me in the right direction to making use of the Quartz64b once again.
(12-16-2025, 02:34 AM)S265 Wrote: Hi all. Is anyone using the Pcie connector on the back of the Quartz64b ? I am revisiting this board after some considerable time. Lets say it has been in storage. Anyway I would like to make use of it again. Which brings me to the Pcie part, Is this used with a flat cable? or is a M.2 card able to be plugged directly into this ? I cannot find much information about it. Has anyone seen a compatible hat that may be used with this connector ? Your comments/experience may point me in the right direction to making use of the Quartz64b once again.
Still going with this. Would this be a M.2 connector?  It is 22mm wide. Any ideas?
.........but M.2 usually have screws for holding the card.
It may be a socket for a flat cable I suppose, not requiring any of the retaining screws on the M.2.
