02-07-2025, 11:35 AM (This post was last modified: 02-07-2025, 11:37 AM by JadenSki.)
Hello all,
I have set up my PPP following @mikehenson's guide. I have everything I need in order to daily drive the phone working. With the exception of mms. Unfortunately I have to have mms working in order to daily drive it. I initially thought the issue might be something I didn't configure correctly, or something in the software side of things. I have since come to the conclusion that it must be a problem on the Tracfone side of things. I am using T-Mobile through Tracfone as my provider. I have data and sms working, I just can't get mms figured out. I started off using T-Mobile's APN and MMSC settings, however though I had sms and data I could not send or receive mms. I then tried Tracfone's recommended settings, and the settings listed here, both with the same results. I've also tried many other combinations of APNs, MMSCs, and Proxies from all over the web. I think part of the problem at least might have to do with the Verizon Migration of Tracfone, and the resulting chaos of the transfer, but I don't know for sure. This brings me to my question: Does anyone here use Tracfone on their ppp, or have any experience with it? If so how/did you get it working, and with what settings? Any insight would be much appreciated.
Thanks!
(02-07-2025, 11:35 AM)JadenSki Wrote: Hello all,
Thanks!
Thanks for the tag!
I have noticed that I can not send or receive MMS if I am connected to a WiFi network... I can turn off WiFi and MMS goes out and comes in.
There are 2 locations that an APN and MMSC needs set.
Chatty >> Perferences >> Protocal >>SMS/MMS
System settings >> Mobile Network >> Advanced >> Access Point Names >> T-Mobile
Thanks!
Thanks for the tag!
