Does USB host or client work on your 2nd batch PineNote?
Worked out of box, continues to work after updates
0%
0
Worked out of box, stopped working after updates
0%
0
Does not work now, do not know about out of box
66.67%
2
Did not work out of box, works after update
0%
0
Never worked
33.33%
1
3 vote(s)
USB host/client working on PineNote 2nd batch?
This poll is to determine how widespread the problem is with the PineNote USB not working as an USB client or host. (Charging works and serial port dongle work.) If you are voting regarding a first batch (pre 2024) PineNote, please make a post saying so to this thread and whether you are running the pinenote-debian-image supplied on the 2nd batch PineNotes.
Symptoms are that the lsusb command gives no results, sudo /usr/bin/dmesg | tail shows nothing new after plugging in a hub, flash drive,or other USB device, and sudo /usr/bin/dmesg | tail on a linux computer shows nothing new after connecting the computer and PineNote by USB.
Also /sys/bus/usb/devices is empty on the PineNote.
As @j_s was mentioning in the UsrMerge thread, this seems related to some errors showing up in the update process, such as
Extracting templates from packages: 100% Preconfiguring packages ... cat: '/sys/bus/usb/devices/*:*/bInterfaceClass': No such file or directory cat: '/sys/bus/usb/devices/*:*/bInterfaceSubClass': No such file or directory cat: '/sys/bus/usb/devices/*:*/bInterfaceProtocol': No such file or directory
I'm still hopting that this is a fixable software issue, but I've found a notice (not warning) in:
https://wiki.pine64.org/wiki/PineNote#UART_Dongle
Quote:The UART adapter is not symmetrically wired, make sure to orient it with the components oriented towards the screen!
that the UART dongle must be plugged into the PineNote component side up because the connector is not wired to support both orientations. So I have to wonder whether inadvertantly plugging it in upside down might kill the USB port, leaving charging and UART capabilities intact.
In this poll, I want to vote "Never worked", but I didn't find any way to enter a vote in this page...
The USB system didn't work for me since unpacking the Pinenote, before any update and  before I first used the UART adapter.
A full system upgrade with
apt update && apt upgrade
and the installation of last kernel linux-image-6.12.6-pinenote-202412310358-00187-g0aa6f8665258 didn't solve this issue.
I have found that the USB system seems to be correctly recognized in the U-Boot console. The "usb start" command gives :
starting USB... Bus dwc3@fcc00000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus dwc3@fd000000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus dwc3@fcc00000 for devices... 1 USB Device(s) found scanning bus dwc3@fd000000 for devices... 1 USB Device(s) found       scanning usb for storage devices... 0 Storage Device(s) found
and "usb tree" gives :
USB device tree:   1  Hub (5 Gb/s, 0mA)     U-Boot XHCI Host Controller   1  Hub (5 Gb/s, 0mA)     U-Boot XHCI Host Controller
I have found that in the rk3566-pinenote-v1.2.dtb file, the nodes usb@fd000000, usb@fd800000, usb@fd840000, usb@fd880000, usb@fd8c0000, usb2phy@fe8a0000/host-port and usb2phy@fe8b0000/host-port have their "status" property set to "disabled". Only usb@fcc00000 has it's status set to "okay".
In my PinePhone Pro under Mobian, on which the USB system is working, all the nodes corresponding to the disabled one have their "status" property set to "okay" in it's .dtb file.
I have tried to modify my PineNote .dtb file by setting the "status" attribute to "okay" to the said nodes, with the "fdtput" command. This makes the corresponding devices appear in /sys/devices/platform as .usb directories but in the output of "journalctl -a", I can see
platform fd000000.usb: deferred probe pending: dwc3: failed to initialize core
and "lsusb" still gives nothing.
Hope this helps...
@cmermoud
Thank you for your very detailed report.
Maybe you need more posts before you can vote in a poll. I am also not able to give a thumbs up to your post because there is no button for it, maybe for the same reason.
If you have a github account, please add a comment with the same information to issue #106 for the pinenote-debian-image repository at:
https://github.com/PNDeb/pinenote-debian...issues/106
(01-16-2025, 10:31 AM)j_s Wrote: @cmermoud
Thanks for this quick reply.
I have added this info to the issue #106 for the pinenote-debian-image repository.
...and now I can vote! I just did it.
Hello
I managed to make USB working on Pinenote!
Please see my last comment on https://github.com/PNDeb/pinenote-debian-image/issues/106
(02-25-2025, 06:45 PM)cmermoud Wrote: Hello
Can you expand on what you made work regarding USB?
I was expecteding some telnet/ssh over rndis actually, when connected to the PC.
What are you using this host usb mode for? Thanks!
Yes, I can expand...
- Now, lsusb shows something
- USB keyboard, USB Ethernet device, USB storage, all work with this patch on the dtb file. I am even trying to boot the PineNote on a USB key now...
I didn't test USB mouse yet, but I'm sure it works. I didn't test SSH/telnet over rndis either because I don't have any windows machine... Up to now, I connect to the Pinenote through SSH using wifi.
lsusb returns nothing, and plugging in USB peripherals doesn't trigger any new entries in dmesg. I've also tested it with a Linux PC using multiple cables, and still no response on either end. Charging works fine, and serial console via USB-UART is functional, but beyond that, USB seems completely dead.
  Audio recording not working fmolinet 0 2,236 03-25-2025, 03:37 PM
Last Post: fmolinet
  PineNote audio volume rocker button? j_s 5 12,875 08-29-2021, 09:51 AM
Last Post: CounterPillow
