Installer Help !
Hi everyone,
I have a Pine A64 that I want to start using again, and I tried to downloaded the Pine64 installer, to install lunix OS, from the github repo here and it is not functional! Blush
When i was first using this board a few years ago the software worked. The sofware will not let me select a my type of board or what type of software I want to flash to it. I tried downloading it on my Mac and windows, and they both do not work. So then I tried using etcher to flash my sd card with this ububtu arm image but it didnt work either.
When I plug the board in it with the flashed sd card it only turns on with a red light. Does anyone know if it is my SD card or my board. I have not used this in a long time and there isnt much support on it.
Any help will be appreciated Smile !
Hi.
If I know Ubuntu and The Linux Foundation doesn't make kernel for tablets and phones.
You can try flashing different OS images like Debian or Manjaro to see if they work better with your Pine.
  Pine 64 installer OS list blank spamsucks 1 12,995 04-08-2025, 08:16 AM
