postmarketOS: which kernel to choose?
I wanted to give postmarketOS a try, but now I'm a bit confused:
[08:40:47] Device codename: pinetab2 [08:40:51] Which kernel do you want to use with your device? [08:40:51] Available kernels (2): [08:40:51] * v0: Kernel for PineTab 2 Dev Units [08:40:51] * v2: Kernel for PineTab 2 Early Adopter [08:40:51] Kernel [v0]:
I wasn't able to find any information about different PineTab2 versions.
https://pkgs.postmarketos.org/package/ma...-kernel-v0
https://pkgs.postmarketos.org/package/ma...-kernel-v2
you probably want to choose v2 if you purchased your Tab2 from the Pine Store.
it's nice to see there's more progress on img building with pmbootstrap for the PT2, i've been wanting to try it, too, to see the progress on their packaged Gnome Mobile DE
Thanks for your answer!
Yes, I bought it from the EU PineStore (about a year ago). It came with UART adapter etc. and a lot of warnings before ordering, so I was not sure. I guess the Dev version was not to be sold.
(07-15-2024, 10:52 AM)tophneal Wrote: it's nice to see there's more progress on img building with pmbootstrap for the PT2, i've been wanting to try it, too, to see the progress on their packaged Gnome Mobile DE
Yes, PineTab2 support has been finally merged a few weeks ago (https://gitlab.com/postmarketOS/pmaports...uests/4208), but the device codename is only available on "edge" channel ("Rolling release / Most devices / Occasional breakage"). I don't have any experiences with postmarketOS yet, but I used sxmo all the time, so I think it will fit much better than other distributions. And even WiFi should work :-)
Thanks again
  PineTab (early adopters) wifi broken in kernel 6.12 bartgrefte 0 2,291 03-23-2025, 05:25 AM
Last Post: bartgrefte
  user kernel modules and dkms brt64 0 2,086 01-28-2025, 02:26 PM
Last Post: brt64
  New images with 6.1 kernel won't boot (mobian / postmarketos) gischpelino 0 2,559 01-17-2023, 11:36 AM
Last Post: gischpelino
  Booting issue for postmarketos (tow-boot)? olyavi 0 2,533 09-15-2022, 05:38 AM
Last Post: olyavi
  Notes on PostmarketOS wd5gnr 1 4,688 01-24-2021, 08:31 AM
Last Post: wd5gnr
