Accelerometer fail?
Question
Hi, noob here.  I have a PineTime watch which I've had for about two weeks.  I charged it on receipt and have been wearing ever since.
Initially I was able to set it so that it woke up the display on raising my wrist; however yesterday that stopped working.  In the settings there is also an option to wake up with a single or double tap.  Neither of these works.  The watch can be woken by pressing the button, so it seems to be working OK otherwise - but does the refusal to be woken by a movement or a tap indicate that the accelerometer has failed?
Is accelerometer failure a known/likely occurence?  I've seen it mentioned once on the board.
Or could there be another issue; maybe re-starting the watch would help?  If so, can anyone suggest how to do that?
For background, this is a sealed device working with the KiActiv app on Android; so I only have access to the watch functions; KiActive should be receiving movement data for analysis offline.
TIL
  Dead accelerometer Antoine 7 12,960 11-19-2022, 01:46 AM
Last Post: jonasd
