Hello.
I would like to know what is the maximum amperage of the 4-pin JST-XH connector since I am planning on powering 4 HDDs by means of it as well as whether it is possible to set up a staggered spinup configuration with the LSI SAS 9211-4i host bus adapter.
If the 4-pin JST-XH connector output current allows it, the project would entail splicing together two Pine64 power splitters somewhere between the cable input connector and the (seeming) buck converters.
Any advice on a suitable 230V 50Hz AC/DC PSU would also be appreciated.
Thank you.
Thank you.
