I was following an online video tutorial when I got my phone in; I didn't understand how slow my phone was, for when I tried to take a look at it when it was downloading updates it didn't screen on so I thought it turned off and thus I held the power button to turn it on; I must have actually turned it off when it was still updating.
Now I got some corrupted files that I can't fix in the system (believe me I've talked to my linux friends).  So is there any base phone software anywhere around here where I can img on a flash and try again from scratch?  Or should I just get a new phone?
		 (07-04-2023, 06:01 PM)unconsidered Wrote:  So is there any base phone software anywhere around here where I can img on a flash and try again from scratch?
Of course there is, being able to run different OS is the main selling point of the PinePhone.
See
https://wiki.pine64.org/wiki/PinePhone_S...e_Releases for a list of what's available.
PinePhone Beta Edition 3GB RAM - custom firmware v.0.7.4 - ADSP v.30.007 - postmarketOS edge - sxmo
		maybe you have to flash to the EMMC to fix it first
ezik
		08-02-2023, 07:43 AM
(This post was last modified: 08-02-2023, 07:47 AM by LienRag.)
		And how to flash the emmc ?
I have a similar problem (I forgot the password for the OS, also I thought that I installed it on the SD card but apparently I actually installed it on the emmc).
The "getting started" says how to reflash the removable emmc, but I don't know if that's the same thing than how to flash the emmc that comes with the Pinephone (I don't believe it's removable).
Edit : sorry, there's a further section in "getting started" about flashing the Integral emmc.
But they only say how to install another OS on it, what I want is to boot from the SD card (so I can test different OSes).
		Also I tried to just boot on the SD card and re-do the installation with a Pin number I won't forgot, but the phone only boots to the installed OS.
I tried to press the volume bouton down when booting, but it changes nothing.
