openSUSE OS
Is anyone using openSUSE-Tumbleweed-ARM-PLAMO-pinephone.aarch64-2023.03.20-Build74.5? I need some advice. Thanks in advance.
Why don't you ask your actual question? We may be able to help even if we are not running it.
In addition, I am interested in principle in OpenSUSE on the PinePhone and would like to hear of the issues you are running into. If only to decide whether it is even worth my time to try it out at all.
(06-28-2023, 05:15 PM)Kevin Kofler Wrote: Why don't you ask your actual question? We may be able to help even if we are not running it.
I had installed a difficult version. I am now running openSUSE-Tumbleweed-ARM-PHOSH-pinephone.aarch64.raw with some success. My question is how do I close running apps?
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,400 11-17-2025, 07:49 AM
Last Post: danm1988
  openSUSE for Pinephone Alefnode 75 170,460 11-17-2023, 08:37 AM
Last Post: Uturn
