how much time its takes to operate quartz64 A with ubuntu
> 10 hours
0%
0
< 10 hours
0%
0
0 vote(s)
ubuntu eth0 unmanaged dhcp not coming up
image used:
Armbian_23.02.0-trunk.0028_Quartz64a_jammy_edge_6.0.12.img.xz
setting via: armbian-config  not functioning shown as:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
root@quartz64a:~# nano /etc/NetworkManager/NetworkManager.conf  content:
  GNU nano 6.2        /etc/NetworkManager/NetworkManager.conf
[main]
#dns=dnsmasq
rc-manager=file
plugins=ifupdown,keyfile
dhcp=dhcpd
[ifupdown]
managed=true
[device]
wifi.scan-rand-mac-address=no
root@quartz64a:~# ifconfig -a
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet6 fe80::bcf9:f3ff:fe1c:3e5f  prefixlen 64  scopeid 0x20<link>
        ether be:f9:f3:1c:3e:5f  txqueuelen 1000  (Ethernet)
        RX packets 55185  bytes 8376500 (8.3 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 4599  bytes 1247714 (1.2 MB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 70
eth0:avahi: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 169.254.10.106  netmask 255.255.0.0  broadcast 169.254.255.255
        device interrupt 70
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 626  bytes 59154 (59.1 KB)
        TX packets 626  bytes 59154 (59.1 KB)
root@quartz64a:~#
nmcli  output logs are:
root@quartz64a:~# nmcli dev -a
DEVICE  TYPE      STATE      CONNECTION
eth0    ethernet  unmanaged  --
lo      loopback  unmanaged  --
root@quartz64a:~#
board starting:
root@quartz64a:~# reboot now
[85951.642619] watchdog: watchdog0: watchdog did not stop!
[85962.243921] reboot: Restarting system with command 'now'
DDR Version V1.10 20210810
ln
ddrconfig:7
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
tdqss: cs0 dqs0: 24ps, dqs1: -96ps, dqs2: -72ps, dqs3: -168ps,
tdqss: cs1 dqs0: 24ps, dqs1: -96ps, dqs2: -72ps, dqs3: -168ps,
change to: 324MHz
PHY drv:clk:36,ca:36,DQ:29,odt:60
vrefinner:16%, vrefout:41%
dram drv:40,odt:0
clk skew:0x62
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
change to: 780MHz
dram drv:40,odt:0
clk skew:0x58
change to: 1560MHz(final freq)
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x26
cs 0:
the read training result:
DQS0:0x32, DQS1:0x31, DQS2:0x3a, DQS3:0x32,
min  :0x12  0xf 0x14  0xf  0x1  0x7  0x9  0x4 , 0xb  0x7  0x5  0x1  0xe  0xb 0x11  0xa ,
      0x15 0x12  0xf  0xc  0x6  0x1  0x6  0x9 , 0xf  0xd  0x9  0x3 0x13 0x12  0xf 0x15 ,
mid  :0x27 0x27 0x2b 0x26 0x18 0x1c 0x21 0x1c ,0x21 0x21 0x1b 0x18 0x24 0x25 0x27 0x22 ,
      0x2d 0x2b 0x26 0x23 0x1d 0x1b 0x1d 0x20 ,0x27 0x24 0x21 0x1b 0x2b 0x2b 0x28 0x2b ,
max  :0x3d 0x3f 0x42 0x3e 0x2f 0x32 0x39 0x34 ,0x37 0x3b 0x31 0x30 0x3a 0x3f 0x3d 0x3a ,
      0x46 0x45 0x3d 0x3b 0x35 0x35 0x35 0x37 ,0x40 0x3b 0x39 0x34 0x43 0x45 0x42 0x42 ,
range:0x2b 0x30 0x2e 0x2f 0x2e 0x2b 0x30 0x30 ,0x2c 0x34 0x2c 0x2f 0x2c 0x34 0x2c 0x30 ,
      0x31 0x33 0x2e 0x2f 0x2f 0x34 0x2f 0x2e ,0x31 0x2e 0x30 0x31 0x30 0x33 0x33 0x2d ,
the write training result:
DQS0:0x2a, DQS1:0x13, DQS2:0x18, DQS3:0x5,
min  :0x75 0x76 0x78 0x77 0x66 0x69 0x6f 0x6f 0x70 ,0x56 0x55 0x51 0x52 0x58 0x5c 0x5d 0x5a 0x56 ,
      0x66 0x66 0x60 0x60 0x56 0x55 0x58 0x5d 0x60 ,0x52 0x4f 0x4d 0x49 0x56 0x56 0x54 0x58 0x52 ,
mid  :0x8f 0x90 0x93 0x90 0x7d 0x81 0x88 0x86 0x87 ,0x70 0x6e 0x6a 0x6b 0x72 0x73 0x74 0x72 0x70 ,
      0x82 0x80 0x7a 0x7a 0x70 0x6e 0x71 0x75 0x79 ,0x6d 0x69 0x67 0x62 0x6f 0x71 0x6d 0x72 0x6c ,
max  :0xaa 0xab 0xae 0xaa 0x95 0x99 0xa2 0x9d 0x9f ,0x8b 0x88 0x83 0x84 0x8d 0x8a 0x8c 0x8b 0x8a ,
      0x9e 0x9b 0x94 0x94 0x8a 0x88 0x8a 0x8e 0x92 ,0x89 0x84 0x82 0x7b 0x89 0x8c 0x86 0x8c 0x86 ,
range:0x35 0x35 0x36 0x33 0x2f 0x30 0x33 0x2e 0x2f ,0x35 0x33 0x32 0x32 0x35 0x2e 0x2f 0x31 0x34 ,
      0x38 0x35 0x34 0x34 0x34 0x33 0x32 0x31 0x32 ,0x37 0x35 0x35 0x32 0x33 0x36 0x32 0x34 0x34 ,
cs 1:
DQS0:0x36, DQS1:0x34, DQS2:0x38, DQS3:0x32,
min  :0x14 0x10 0x14 0x10  0x1  0x8  0xb  0x5 , 0xb  0x9  0x4  0x3  0xe  0xb 0x12  0xb ,
      0x15 0x10  0xe  0xb  0x5  0x1  0x6  0x9 ,0x10  0xd  0x9  0x2 0x13 0x12 0x10 0x13 ,
mid  :0x2b 0x28 0x2d 0x29 0x1a 0x1f 0x24 0x1e ,0x23 0x23 0x1c 0x1a 0x25 0x26 0x29 0x25 ,
      0x2c 0x28 0x24 0x22 0x1c 0x19 0x1b 0x1f ,0x27 0x23 0x20 0x1a 0x2a 0x2b 0x28 0x2a ,
max  :0x42 0x41 0x46 0x42 0x33 0x37 0x3d 0x37 ,0x3b 0x3d 0x35 0x32 0x3d 0x42 0x41 0x3f ,
      0x44 0x41 0x3a 0x3a 0x33 0x32 0x31 0x35 ,0x3f 0x3a 0x37 0x33 0x41 0x45 0x41 0x42 ,
range:0x2e 0x31 0x32 0x32 0x32 0x2f 0x32 0x32 ,0x30 0x34 0x31 0x2f 0x2f 0x37 0x2f 0x34 ,
      0x2f 0x31 0x2c 0x2f 0x2e 0x31 0x2b 0x2c ,0x2f 0x2d 0x2e 0x31 0x2e 0x33 0x31 0x2f ,
min  :0x76 0x76 0x79 0x78 0x66 0x6a 0x71 0x6f 0x71 ,0x56 0x56 0x52 0x54 0x5a 0x5c 0x5e 0x5a 0x59 ,
      0x67 0x67 0x60 0x61 0x58 0x56 0x58 0x5e 0x60 ,0x51 0x4d 0x4a 0x47 0x54 0x55 0x52 0x56 0x51 ,
mid  :0x91 0x91 0x95 0x92 0x7f 0x82 0x8a 0x86 0x89 ,0x71 0x70 0x6c 0x6e 0x74 0x74 0x76 0x74 0x73 ,
      0x82 0x81 0x7a 0x7b 0x72 0x6f 0x71 0x76 0x79 ,0x6c 0x68 0x66 0x61 0x6e 0x6f 0x6a 0x70 0x6b ,
max  :0xac 0xad 0xb1 0xac 0x98 0x9a 0xa3 0x9e 0xa1 ,0x8d 0x8a 0x86 0x88 0x8e 0x8c 0x8f 0x8e 0x8d ,
      0x9e 0x9b 0x94 0x96 0x8c 0x88 0x8a 0x8e 0x93 ,0x88 0x84 0x82 0x7c 0x88 0x8a 0x83 0x8a 0x85 ,
range:0x36 0x37 0x38 0x34 0x32 0x30 0x32 0x2f 0x30 ,0x37 0x34 0x34 0x34 0x34 0x30 0x31 0x34 0x34 ,
      0x37 0x34 0x34 0x35 0x34 0x32 0x32 0x30 0x33 ,0x37 0x37 0x38 0x35 0x34 0x35 0x31 0x34 0x34 ,
CA Training result:
cs:0 min  :0x43 0x42 0x36 0x32 0x34 0x32 0x40 ,0x3e 0x38 0x34 0x30 0x35 0x2e 0x3f ,
cs:0 mid  :0x81 0x82 0x74 0x72 0x72 0x71 0x6f ,0x7b 0x78 0x71 0x6f 0x71 0x6e 0x6e ,
cs:0 max  :0xbf 0xc2 0xb3 0xb3 0xb1 0xb1 0x9e ,0xb9 0xb8 0xae 0xaf 0xae 0xae 0x9d ,
cs:0 range:0x7c 0x80 0x7d 0x81 0x7d 0x7f 0x5e ,0x7b 0x80 0x7a 0x7f 0x79 0x80 0x5e ,
cs:1 min  :0x40 0x45 0x34 0x34 0x33 0x34 0x40 ,0x3e 0x3d 0x32 0x36 0x34 0x34 0x41 ,
cs:1 mid  :0x81 0x82 0x74 0x71 0x73 0x71 0x70 ,0x7d 0x7a 0x72 0x71 0x74 0x70 0x71 ,
cs:1 max  :0xc2 0xc0 0xb4 0xae 0xb3 0xaf 0xa1 ,0xbd 0xb7 0xb2 0xac 0xb5 0xad 0xa1 ,
cs:1 range:0x82 0x7b 0x80 0x7a 0x80 0x7b 0x61 ,0x7f 0x7a 0x80 0x76 0x81 0x79 0x60 ,
out
U-Boot SPL 2022.10-rc4-armbian (Dec 10 2022 - 11:45:54 +0000)
saradc@fe720000: Can't update Vdd. Error: -38saradc@fe720000: Can't update Vss. Error: -38can't get vref-supply: -38
rockchip_dnl_key_pressed: adc_channel_single_shot fail!
Trying to boot from MMC1
mmc_load_image_raw_sector: mmc block read error
Trying to boot from MMC2
Card did not respond to voltage select! : -110
spl: mmc init failed with error: -95
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-152-g4e725b15f:cl
NOTICE:  BL31: Built : 10:51:13, Jul 15 2021
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    pmu v1 is valid
INFO:    dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:  Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0xa00000
INFO:    SPSR = 0x3c9
U-Boot 2022.10-rc4-armbian (Dec 10 2022 - 11:45:54 +0000)
Model: Pine64 RK3566 Quartz64-A Board
DRAM:  3.7 GiB
PMIC:  RK8170 (on=0x02, off=0x10)
Core:  266 devices, 21 uclasses, devicetree: separate
MMC:  mmc@fe2b0000: 1, mmc@fe310000: 0
Loading Environment from nowhere... OK
In:    serial@fe660000
Out:  serial@fe660000
Err:  serial@fe660000
can't get vref-supply: -2
Net:  No ethernet found.
Hit any key to stop autoboot:  0
starting USB...
Bus usb@fcc00000: Port not available.
Bus usb@fd000000: Port not available.
Bus usb@fd800000: USB EHCI 1.00
Bus usb@fd840000: USB OHCI 1.0
Bus usb@fd880000: USB EHCI 1.00
Bus usb@fd8c0000: USB OHCI 1.0
scanning bus usb@fd800000 for devices... 1 USB Device(s) found
scanning bus usb@fd840000 for devices... ERROR:  USB-error: DEVICENOTRESPONDING: Device did not respond to token (IN) or did
not provide a handshake (OUT) (5)
unable to get device descriptor (error=-1)
scanning bus usb@fd880000 for devices... 1 USB Device(s) found
scanning bus usb@fd8c0000 for devices... 1 USB Device(s) found
      scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1:      Armbian
Retrieving file: /boot/uInitrd
Retrieving file: /boot/Image
append: root=UUID=c0c08e7f-14a1-4691-8282-786f3ff1421b console=ttyS02,1500000 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 bootsplash.bootfile=bootsplash.armbian
Retrieving file: /boot/dtb/rockchip/rk3566-quartz64-a.dtb
Moving Image from 0x2080000 to 0x2200000, end=4160000
## Loading init Ramdisk from Legacy Image at 0a200000 ...
  Image Name:  uInitrd
  Image Type:  AArch64 Linux RAMDisk Image (gzip compressed)
  Data Size:    29197642 Bytes = 27.8 MiB
  Load Address: 00000000
  Entry Point:  00000000
  Verifying Checksum ... OK
## Flattened Device Tree blob at 0a100000
  Booting using the fdt blob at 0xa100000
  Loading Ramdisk to ec30c000, end edee454a ... OK
  Loading Device Tree to 00000000ec2ee000, end 00000000ec30beb0 ... OK
Starting kernel ...
efi_free_pool: illegal free 0x00000000ecee7040
efi_free_pool: illegal free 0x00000000ecee4040
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 6.0.12-media (root@a478b43a3232) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #trunk.0025 SMP PREEMPT Thu Dec 8 15:09:46 UTC 2022
[    0.000000] Machine model: Pine64 RK3566 Quartz64-A Board
[    0.000000] efi: UEFI not found.
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xef7e8a40-0xef7eafff]
[    0.000000] Zone ranges:
[    0.000000]  DMA      [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000]  DMA32    empty
[    0.000000]  Normal  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]  node  0: [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] cma: Reserved 384 MiB at 0x00000000d0600000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 30 pages/cpu s83304 r8192 d31384 u122880
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: patching kernel code
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 967176
[    0.000000] Policy zone: DMA
[    0.000000] Kernel command line: root=UUID=c0c08e7f-14a1-4691-8282-786f3ff1421b console=ttyS02,1500000 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 bootsplash.bootfile=bootsplash.armbian
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 3399788K/3930112K available (16960K kernel code, 2882K rwdata, 7016K rodata, 4352K init, 741K bss, 137108K reserved, 393216K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:    RCU event tracing is enabled.
[    0.000000] rcu:    RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 320 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: MBI range [296:319]
[    0.000000] GICv3: Using MBI frame 0x00000000fd410000
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001738] Console: colour dummy device 80x25
[    0.002455] printk: console [tty0] enabled
[    0.002631] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002678] pid_max: default: 32768 minimum: 301
[    0.002999] LSM: Security Framework initializing
[    0.003113] Yama: becoming mindful.
[    0.003318] AppArmor: AppArmor initialized
[    0.003613] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.003671] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005704] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.007256] cblist_init_generic: Setting adjustable number of callback queues.
[    0.007296] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.007503] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.007998] rcu: Hierarchical SRCU implementation.
[    0.008025] rcu:    Max phase no-delay instances is 1000.
[    0.016488] EFI services will not be available.
[    0.017342] smp: Bringing up secondary CPUs ...
[    0.018608] Detected VIPT I-cache on CPU1
[    0.018739] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    0.018764] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.018832] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.020180] Detected VIPT I-cache on CPU2
[    0.020301] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    0.020325] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.020379] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.021775] Detected VIPT I-cache on CPU3
[    0.021900] cacheinfo: Unable to detect cache hierarchy for CPU 3
[    0.021924] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.021976] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.022166] smp: Brought up 1 node, 4 CPUs
[    0.022343] SMP: Total of 4 processors activated.
[    0.022364] CPU features: detected: 32-bit EL0 Support
[    0.022383] CPU features: detected: 32-bit EL1 Support
[    0.022403] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.022428] CPU features: detected: Common not Private translations
[    0.022447] CPU features: detected: CRC32 instructions
[    0.022469] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.022488] CPU features: detected: LSE atomic instructions
[    0.022506] CPU features: detected: Privileged Access Never
[    0.022525] CPU features: detected: RAS Extension Support
[    0.022547] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.047588] CPU: All CPU(s) started at EL2
[    0.051552] devtmpfs: initialized
[    0.082382] Registered cp15_barrier emulation handler
[    0.082440] Registered setend emulation handler
[    0.082781] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.082854] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.095167] pinctrl core: initialized pinctrl subsystem
[    0.096359] DMI not present or invalid.
[    0.097520] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.100400] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.101933] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.103188] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.103312] audit: initializing netlink subsys (disabled)
[    0.103684] audit: type=2000 audit(0.100:1): state=initialized audit_enabled=0 res=1
[    0.105171] thermal_sys: Registered thermal governor 'fair_share'
[    0.105184] thermal_sys: Registered thermal governor 'bang_bang'
[    0.105213] thermal_sys: Registered thermal governor 'step_wise'
[    0.105235] thermal_sys: Registered thermal governor 'user_space'
[    0.105256] thermal_sys: Registered thermal governor 'power_allocator'
[    0.106326] cpuidle: using governor ladder
[    0.106414] cpuidle: using governor menu
[    0.106987] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.107233] ASID allocator initialised with 65536 entries
[    0.109542] Serial: AMBA PL011 UART driver
[    0.130257] platform fe0a0000.hdmi: Fixing up cyclic dependency with fe040000.vop
[    0.179281] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    0.180509] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    0.181611] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    0.182627] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    0.183744] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    0.188433] platform hdmi-con: Fixing up cyclic dependency with fe0a0000.hdmi
[    0.202421] KASLR disabled due to lack of seed
[    0.224219] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.224267] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.224293] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.224314] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
[    0.224338] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.224359] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.224381] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.224401] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.226006] cryptd: max_cpu_qlen set to 1000
[    0.292143] raid6: neonx8  gen()  1371 MB/s
[    0.360291] raid6: neonx4  gen()  1415 MB/s
[    0.428426] raid6: neonx2  gen()  1262 MB/s
[    0.496591] raid6: neonx1  gen()  1016 MB/s
[    0.564729] raid6: int64x8  gen()  1016 MB/s
[    0.632855] raid6: int64x4  gen()  1082 MB/s
[    0.701005] raid6: int64x2  gen()  962 MB/s
[    0.769161] raid6: int64x1  gen()  697 MB/s
[    0.769185] raid6: using algorithm neonx4 gen() 1415 MB/s
[    0.837297] raid6: .... xor() 1074 MB/s, rmw enabled
[    0.837322] raid6: using neon recovery algorithm
[    0.838765] ACPI: Interpreter disabled.
[    0.844030] iommu: Default domain type: Translated
[    0.844075] iommu: DMA domain TLB invalidation policy: strict mode
[    0.845013] SCSI subsystem initialized
[    0.845809] usbcore: registered new interface driver usbfs
[    0.845929] usbcore: registered new interface driver hub
[    0.846004] usbcore: registered new device driver usb
[    0.846967] pps_core: LinuxPPS API ver. 1 registered
[    0.846994] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.847044] PTP clock support registered
[    0.847783] EDAC MC: Ver: 3.0.0
[    0.849160] arm-scmi firmwareConfusedcmi: Enabled polling mode TX channel - prot_id:16
[    0.849423] arm-scmi firmwareConfusedcmi: SCMI Notifications - Core Enabled.
[    0.849549] arm-scmi firmwareConfusedcmi: Malformed reply - real_sz:8  calc_sz:4  (loop_num_ret:1)
[    0.849588] arm-scmi firmwareConfusedcmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    0.851074] FPGA manager framework
[    0.852294] NetLabel: Initializing
[    0.852321] NetLabel:  domain hash size = 128
[    0.852340] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.852457] NetLabel:  unlabeled traffic allowed by default
[    0.852718] vgaarb: loaded
[    0.853550] clocksource: Switched to clocksource arch_sys_counter
[    0.854365] VFS: Disk quotas dquot_6.6.0
[    0.854494] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.855787] AppArmor: AppArmor Filesystem Enabled
[    0.855927] pnp: PnP ACPI: disabled
[    0.872772] NET: Registered PF_INET protocol family
[    0.873218] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.877854] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.878155] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.878290] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.878734] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.879222] TCP: Hash tables configured (established 32768 bind 32768)
[    0.879498] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.879643] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.880103] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.880180] NET: Registered PF_XDP protocol family
[    0.880214] PCI: CLS 0 bytes, default 64
[    0.880683] Trying to unpack rootfs image as initramfs...
[    0.891257] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    0.892500] kvm [1]: IPA Size Limit: 40 bits
[    0.892611] kvm [1]: GICv3: no GICV resource entry
[    0.892639] kvm [1]: disabling GICv2 emulation
[    0.892689] kvm [1]: GIC system register CPU interface enabled
[    0.892994] kvm [1]: vgic interrupt IRQ9
[    0.893297] kvm [1]: VHE mode initialized successfully
[    0.896872] Initialise system trusted keyrings
[    0.896983] Key type blacklist registered
[    0.897420] workingset: timestamp_bits=42 max_order=20 bucket_order=0
[    0.907556] zbud: loaded
[    0.911161] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.912640] fuse: init (API version 7.36)
[    0.917037] integrity: Platform Keyring initialized
[    0.969874] xor: measuring software checksum speed
[    0.975485]    8regs          :  1777 MB/sec
[    0.981819]    32regs          :  1577 MB/sec
[    0.988618]    arm64_neon      :  1475 MB/sec
[    0.988649] xor: using function: 8regs (1777 MB/sec)
[    0.988682] Key type asymmetric registered
[    0.988703] Asymmetric key parser 'x509' registered
[    2.670332] Freeing initrd memory: 28512K
[    2.695830] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[    2.696016] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    2.696294] io scheduler mq-deadline registered
[    2.696325] io scheduler kyber registered
[    2.696587] io scheduler bfq registered
[    2.719861] EINJ: ACPI disabled.
[    2.731278] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.731333] dma-pl330 fe530000.dma-controller:      DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    2.735204] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.735252] dma-pl330 fe550000.dma-controller:      DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    2.741851] arm-scmi firmwareConfusedcmi: Failed. SCMI protocol 22 not active.
[    2.749034] Serial: 8250/16550 driver, 8 ports, IRQ sharing enabled
[    2.754602] fdd50000.serial: ttyS0 at MMIO 0xfdd50000 (irq = 29, base_baud = 1500000) is a 16550A
[    2.756701] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 30, base_baud = 1500000) is a 16550A
[    2.756966] serial serial0: tty port ttyS1 registered
[    2.758573] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 31, base_baud = 1500000) is a 16550A
[    2.876936] printk: console [ttyS2] enabled
[    2.879423] Serial: AMBA driver
[    2.883195] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.899398] brd: module loaded
[    2.912339] loop: module loaded
[    2.925101] thunder_xcv, ver 1.0
[    2.925517] thunder_bgx, ver 1.0
[    2.925918] nicpf, ver 1.0
[    2.927576] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.928239] hns3: Copyright © 2017 Huawei Corporation.
[    2.928891] hclge is initializing
[    2.931545] VFIO - User Level meta-driver version: 0.3
[    2.935877] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.936553] ehci-pci: EHCI PCI platform driver
[    2.937055] ehci-platform: EHCI generic platform driver
[    2.938018] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.938617] ohci-pci: OHCI PCI platform driver
[    2.939109] ohci-platform: OHCI generic platform driver
[    2.940330] ehci-platform fd880000.usb: EHCI Host Controller
[    2.940426] ehci-platform fd800000.usb: EHCI Host Controller
[    2.940558] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[    2.940593] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 1
[    2.940804] ohci-platform fd8c0000.usb: irq 37, io mem 0xfd8c0000
[    2.940890] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[    2.940943] usbcore: registered new interface driver usb-storage
[    2.941405] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 3
[    2.942221] ehci-platform fd880000.usb: irq 35, io mem 0xfd880000
[    2.942924] ehci-platform fd800000.usb: irq 34, io mem 0xfd800000
[    2.944216] ohci-platform fd840000.usb: Generic Platform OHCI controller
[    2.945827] mousedev: PS/2 mouse device common for all mice
[    2.945873] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 4
[    2.948079] i2c_dev: i2c /dev entries driver
[    2.948393] ohci-platform fd840000.usb: irq 36, io mem 0xfd840000
[    2.951502] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    2.957623] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[    2.958580] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[    2.959344] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.960003] usb usb2: Product: EHCI Host Controller
[    2.960453] usb usb2: Manufacturer: Linux 6.0.12-media ehci_hcd
[    2.960992] usb usb2: SerialNumber: fd880000.usb
[    2.962089] clk: failed to reparent i2s1_mclkout_tx to clk_i2s1_8ch_tx: -22
[    2.962441] hub 2-0:1.0: USB hub found
[    2.963148] hub 2-0:1.0: 1 port detected
[    2.963765] rk808 0-0020: chip id: 0x8170
[    2.973585] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[    2.974824] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[    2.975589] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.976248] usb usb3: Product: EHCI Host Controller
[    2.976697] usb usb3: Manufacturer: Linux 6.0.12-media ehci_hcd
[    2.977239] usb usb3: SerialNumber: fd800000.usb
[    2.978490] hub 3-0:1.0: USB hub found
[    2.978902] hub 3-0:1.0: 1 port detected
[    3.001879] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.00
[    3.002645] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.003305] usb usb1: Product: Generic Platform OHCI controller
[    3.003847] usb usb1: Manufacturer: Linux 6.0.12-media ohci_hcd
[    3.004387] usb usb1: SerialNumber: fd8c0000.usb
[    3.005636] hub 1-0:1.0: USB hub found
[    3.006052] hub 1-0:1.0: 1 port detected
[    3.009884] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.00
[    3.010654] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.010871] clk: failed to reparent i2s1_mclkout_tx to clk_i2s1_8ch_tx: -22
[    3.011313] usb usb4: Product: Generic Platform OHCI controller
[    3.011734] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    3.011957] usb usb4: Manufacturer: Linux 6.0.12-media ohci_hcd
[    3.012004] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    3.012511] usb usb4: SerialNumber: fd840000.usb
[    3.012531] rk808-regulator rk808-regulator: max buck steps per change: 8
[    3.015975] hub 4-0:1.0: USB hub found
[    3.016393] hub 4-0:1.0: 1 port detected
[    3.084028] boost: Bringing 4700000uV into 5000000-5000000uV
[    3.099770] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[    3.113445] rk808-rtc rk808-rtc: registered as rtc0
[    3.116724] rk808-rtc rk808-rtc: setting system clock to 2017-09-19T12:00:06 UTC (1505822406)
[    3.136031] sdhci: Secure Digital Host Controller Interface driver
[    3.136598] sdhci: Copyright© Pierre Ossman
[    3.137409] Synopsys Designware Multimedia Card Interface Driver
[    3.138755] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.139711] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    3.140370] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    3.140969] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    3.141516] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 67,32 bit host data width,256 deep fifo
[    3.142779] ledtrig-cpu: registered to indicate activity on CPUs
[    3.143775] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    3.143952] No iBFT detected.
[    3.144306] mmc_host mmc2: card is non-removable.
[    3.144812] arm-scmi firmwareConfusedcmi: Failed. SCMI protocol 17 not active.
[    3.145675] SMCCC: SOC_ID: ARCH_FEATURES(ARCH_SOC_ID) returned error: fffffffffffffffd
[    3.146634] hid: raw HID events driver © Jiri Kosina
[    3.147224] usbcore: registered new interface driver usbhid
[    3.147722] usbhid: USB HID core driver
[    3.153328] NET: Registered PF_INET6 protocol family
[    3.166302] Segment Routing with IPv6
[    3.166728] In-situ OAM (IOAM) with IPv6
[    3.167174] NET: Registered PF_PACKET protocol family
[    3.167789] 8021q: 802.1Q VLAN Support v1.8
[    3.168222] Key type dns_resolver registered
[    3.169822] registered taskstats version 1
[    3.170220] Loading compiled-in X.509 certificates
[    3.173596] mmc1: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    3.173722] Loaded X.509 cert 'Build time autogenerated kernel key: 58b59c4e066bb0929f80de7ff94a7a738c9fc225'
[    3.179175] zswap: loaded using pool zstd/z3fold
[    3.180177] Key type .fscrypt registered
[    3.180533] Key type fscrypt-provisioning registered
[    3.182911] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[    3.183961] Key type encrypted registered
[    3.184340] AppArmor: AppArmor sha1 policy hashing enabled
[    3.184857] ima: No TPM chip found, activating TPM-bypass!
[    3.185365] ima: Allocated hash algorithm: sha1
[    3.185820] ima: No architecture policies found
[    3.186287] evm: Initialising EVM extended attributes:
[    3.186746] evm: security.selinux
[    3.187046] evm: security.SMACK64
[    3.187343] evm: security.SMACK64EXEC
[    3.187673] evm: security.SMACK64TRANSMUTE
[    3.188038] evm: security.SMACK64MMAP
[    3.188366] evm: security.apparmor
[    3.188670] evm: security.ima
[    3.188935] evm: security.capability
[    3.189254] evm: HMAC attrs: 0x1
[    3.237493] reg-fixed-voltage vcc5v0_usb20_otg: nonexclusive access to GPIO for vcc5v0_usb20_otg
[    3.245113] rockchip-dw-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges:
[    3.245926] rockchip-dw-pcie 3c0000000.pcie:      IO 0x033ef00000..0x033effffff -> 0x003ef00000
[    3.246729] rockchip-dw-pcie 3c0000000.pcie:      MEM 0x0300000000..0x033eefffff -> 0x0000000000
[    3.247773] rockchip-dw-pcie 3c0000000.pcie: iATU unroll: enabled
[    3.248334] rockchip-dw-pcie 3c0000000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G
[    3.269673] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.354915] rockchip-dw-pcie 3c0000000.pcie: Phy link never came up
[    4.356000] rockchip-dw-pcie 3c0000000.pcie: PCI host bridge to bus 0000:00
[    4.356689] pci_bus 0000:00: root bus resource [bus 00-0f]
[    4.357237] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0x3ef00000-0x3effffff])
[    4.358344] pci_bus 0000:00: root bus resource [mem 0x300000000-0x33eefffff] (bus address [0x00000000-0x3eefffff])
[    4.359424] pci 0000:00:00.0: [1d87:3566] type 01 class 0x060400
[    4.360084] pci 0000:00:00.0: reg 0x38: [mem 0x300000000-0x30000ffff pref]
[    4.361015] pci 0000:00:00.0: supports D1 D2
[    4.361450] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    4.373053] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f])
[    4.374256] pci 0000:00:00.0: BAR 6: assigned [mem 0x300000000-0x30000ffff pref]
[    4.374926] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    4.375501] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[    4.387782] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    4.389354] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    4.390282] rk_gmac-dwmac fe010000.ethernet: TX delay(0x30).
[    4.390878] rk_gmac-dwmac fe010000.ethernet: RX delay(0x10).
[    4.391501] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    4.392261] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    4.397915] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    4.398851] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    4.399535] rk_gmac-dwmac fe010000.ethernet:        DWMAC4/5
[    4.400023] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    4.400723] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    4.401411] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    4.402108] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    4.402796] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    4.403327] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    4.404080] rk_gmac-dwmac fe010000.ethernet: device MAC address 8e:75:02:85:36:c0
[    4.404789] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    4.405454] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    4.406050] rk_gmac-dwmac fe010000.ethernet: Using 32 bits DMA width
[    4.563662] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    4.564183] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 5
[    4.564986] xhci-hcd xhci-hcd.1.auto: USB3 root hub has no ports
[    4.565526] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    4.566634] xhci-hcd xhci-hcd.1.auto: irq 72, io mem 0xfcc00000
[    4.567619] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[    4.568408] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.569072] usb usb5: Product: xHCI Host Controller
[    4.569575] usb usb5: Manufacturer: Linux 6.0.12-media xhci-hcd
[    4.570114] usb usb5: SerialNumber: xhci-hcd.1.auto
[    4.571220] hub 5-0:1.0: USB hub found
[    4.571604] hub 5-0:1.0: 1 port detected
[    4.576306] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    4.576830] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 6
[    4.577697] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    4.578600] xhci-hcd xhci-hcd.2.auto: irq 73, io mem 0xfd000000
[    4.579329] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    4.579893] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 7
[    4.580586] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[    4.581354] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[    4.582112] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.582760] usb usb6: Product: xHCI Host Controller
[    4.583198] usb usb6: Manufacturer: Linux 6.0.12-media xhci-hcd
[    4.583728] usb usb6: SerialNumber: xhci-hcd.2.auto
[    4.584691] hub 6-0:1.0: USB hub found
[    4.585067] hub 6-0:1.0: 1 port detected
[    4.585871] usb usb7: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.586730] usb usb7: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.00
[    4.587470] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.588115] usb usb7: Product: xHCI Host Controller
[    4.588554] usb usb7: Manufacturer: Linux 6.0.12-media xhci-hcd
[    4.589083] usb usb7: SerialNumber: xhci-hcd.2.auto
[    4.590171] hub 7-0:1.0: USB hub found
[    4.590595] hub 7-0:1.0: 1 port detected
[    4.592620] printk: console [netcon0] enabled
[    4.593031] netconsole: network logging started
[    4.593688] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    4.593818] psci_checker: PSCI checker started using 4 CPUs
[    4.594349] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    4.594821] psci_checker: Starting hotplug tests
[    4.594833] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    4.595416] psci_checker: Trying to turn off and on again all CPUs
[    4.597281] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 74,32 bit host data width,256 deep fifo
[    4.598503] psci: CPU0 killed (polled 0 ms)
[    4.600340] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[    4.603093] psci: CPU1 killed (polled 0 ms)
[    4.605850] psci: CPU2 killed (polled 0 ms)
[    4.609463] Detected VIPT I-cache on CPU0
[    4.609922] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    4.610480] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    4.611169] CPU0: Booted secondary processor 0x0000000000 [0x412fd050]
[    4.613729] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.614240] Detected VIPT I-cache on CPU1
[    4.615015] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    4.615565] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    4.616246] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    4.619116] Detected VIPT I-cache on CPU2
[    4.619589] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    4.620142] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    4.620824] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    4.622728] psci_checker: Trying to turn off and on again group 0 (CPUs 0-3)
[    4.625562] psci: CPU0 killed (polled 0 ms)
[    4.630056] psci: CPU1 killed (polled 0 ms)
[    4.633607] psci: CPU2 killed (polled 0 ms)
[    4.636868] Detected VIPT I-cache on CPU0
[    4.637329] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    4.637888] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    4.638577] CPU0: Booted secondary processor 0x0000000000 [0x412fd050]
[    4.641228] Detected VIPT I-cache on CPU1
[    4.641648] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    4.642195] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    4.642865] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    4.645338] Detected VIPT I-cache on CPU2
[    4.645788] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    4.646335] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    4.647004] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    4.648853] psci_checker: Hotplug tests passed OK
[    4.649281] psci_checker: Starting suspend tests (10 cycles per state)
[    4.650131] psci_checker: cpuidle not available on CPU 0, ignoring
[    4.650684] psci_checker: cpuidle not available on CPU 1, ignoring
[    4.651232] psci_checker: cpuidle not available on CPU 2, ignoring
[    4.651780] psci_checker: cpuidle not available on CPU 3, ignoring
[    4.652329] psci_checker: Could not start suspend tests on any CPU
[    4.652875] psci_checker: PSCI checker completed
[    4.653289] of_cfs_init
[    4.653564] of_cfs_init: OK
[    4.656265] Freeing unused kernel memory: 4352K
[    4.677861] Run /init as init process
[    4.710064] mmc_host mmc0: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[    4.854789] dwmmc_rockchip fe2b0000.mmc: Successfully tuned phase to 34
[    4.855421] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[    4.857010] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
[    4.864825]  mmcblk0: p1
[    5.225301] panfrost fde60000.gpu: clock rate = 594000000
[    5.225905] panfrost fde60000.gpu: bus_clock rate = 500000000
[    5.250091] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    5.250809] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    5.258817] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    5.259906] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    5.267169] rockchip-vop2 fe040000.vop: Adding to iommu group 1
[    5.268879] [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 0
[    5.275141] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm])
[    5.277771] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    5.279516] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    5.280962] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[    5.282596] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[    5.283429] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    5.284195] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    6.895705] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
[    7.426627] systemd[1]: System time before build time, advancing clock.
[    7.448426] systemd[1]: Inserted module 'autofs4'
[    7.508454] systemd[1]: systemd 249.11-0ubuntu3.6 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    7.512681] systemd[1]: Detected architecture arm64.
[    7.516284] systemd[1]: Hostname set to <quartz64a>.
[    7.642411] dw-apb-uart fe660000.serial: forbid DMA for kernel console
[    8.213694] systemd[1]: Queued start job for default target Graphical Interface.
[  11.741597] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[  12.721549] random: crng init done
[  12.746492] systemd[1]: Created slice Slice /system/modprobe.
[  12.752849] systemd[1]: Created slice Slice /system/serial-getty.
[  12.754726] systemd[1]: Created slice User and Session Slice.
[  12.755794] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  12.757459] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[  12.758969] systemd[1]: Reached target Slice Units.
[  12.759624] systemd[1]: Reached target Swaps.
[  12.760201] systemd[1]: Reached target System Time Set.
[  12.760977] systemd[1]: Reached target Local Verity Protected Volumes.
[  12.777501] systemd[1]: Listening on RPCbind Server Activation Socket.
[  12.779324] systemd[1]: Listening on Syslog Socket.
[  12.780876] systemd[1]: Listening on fsck to fsckd communication Socket.
[  12.782231] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  12.784297] systemd[1]: Listening on Journal Audit Socket.
[  12.785917] systemd[1]: Listening on Journal Socket (/dev/log).
[  12.787629] systemd[1]: Listening on Journal Socket.
[  12.788775] systemd[1]: systemd-networkd.socket: Socket service systemd-networkd.service not loaded, refusing.
[  12.789735] systemd[1]: Failed to listen on Network Service Netlink Socket.
[  12.791992] systemd[1]: Listening on udev Control Socket.
[  12.793581] systemd[1]: Listening on udev Kernel Socket.
[  12.797776] systemd[1]: Mounting Huge Pages File System...
[  12.802307] systemd[1]: Mounting POSIX Message Queue File System...
[  12.807219] systemd[1]: Mounting Kernel Debug File System...
[  12.812005] systemd[1]: Mounting Kernel Trace File System...
[  12.813419] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[  12.823760] systemd[1]: Starting Restore / save the current clock...
[  12.830661] systemd[1]: Starting Wait for network to be configured by ifupdown...
[  12.837423] systemd[1]: Starting Set the console keyboard layout...
[  12.842923] systemd[1]: Starting Create List of Static Device Nodes...
[  12.849147] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[  12.854862] systemd[1]: Starting Load Kernel Module configfs...
[  12.867061] systemd[1]: Starting Load Kernel Module drm...
[  12.873600] systemd[1]: Starting Load Kernel Module efi_pstore...
[  12.879555] systemd[1]: Starting Load Kernel Module fuse...
[  12.885276] systemd[1]: Starting Load Kernel Module pstore_blk...
[  12.891396] systemd[1]: Starting Load Kernel Module pstore_zone...
[  12.897060] systemd[1]: Starting Load Kernel Module ramoops...
[  12.902891] systemd[1]: Started Nameserver information manager.
[  12.904921] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[  12.914216] systemd[1]: Starting Load Kernel Modules...
[  12.919245] systemd[1]: Starting Generate network units from Kernel command line...
[  12.925246] systemd[1]: Starting Wait for Network to be Configured...
[  12.931025] systemd[1]: Starting Remount Root and Kernel File Systems...
[  12.937186] systemd[1]: Starting Coldplug All udev Devices...
[  12.949082] systemd[1]: Mounted Huge Pages File System.
[  12.950661] systemd[1]: Mounted POSIX Message Queue File System.
[  12.952206] systemd[1]: Mounted Kernel Debug File System.
[  12.953946] systemd[1]: Mounted Kernel Trace File System.
[  12.956748] systemd[1]: Finished Restore / save the current clock.
[  12.959747] systemd[1]: Finished Create List of Static Device Nodes.
[  12.962245] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
[  12.964464] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[  12.965014] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
[  12.970252] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[  12.972184] systemd[1]: Finished Load Kernel Module configfs.
[  12.974333] systemd[1]: modprobe@drm.service: Deactivated successfully.
[  12.976223] systemd[1]: Finished Load Kernel Module drm.
[  12.979234] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[  12.981186] systemd[1]: Finished Load Kernel Module efi_pstore.
[  12.983336] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[  12.985235] systemd[1]: Finished Load Kernel Module fuse.
[  12.987722] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
[  12.989748] systemd[1]: Finished Load Kernel Module pstore_blk.
[  12.991861] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
[  12.994406] systemd[1]: Finished Load Kernel Module pstore_zone.
[  12.996448] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
[  12.998465] systemd[1]: Finished Load Kernel Module ramoops.
[  13.002593] systemd[1]: Finished Load Kernel Modules.
[  13.005013] systemd[1]: Finished Generate network units from Kernel command line.
[  13.008123] systemd[1]: Finished Remount Root and Kernel File Systems.
[  13.009874] systemd[1]: Reached target Preparation for Network.
[  13.030628] systemd[1]: Mounting FUSE Control File System...
[  13.035226] systemd[1]: Mounting Kernel Configuration File System...
[  13.036419] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[  13.041828] systemd[1]: Starting Load/Save Random Seed...
[  13.046774] systemd[1]: Starting Apply Kernel Variables...
[  13.052025] systemd[1]: Starting Create System Users...
[  13.059050] systemd[1]: Finished Set the console keyboard layout.
[  13.064700] systemd[1]: Mounted FUSE Control File System.
[  13.066282] systemd[1]: Mounted Kernel Configuration File System.
[  15.101977] of_dma_request_slave_channel: dma-names property of node '/serial@fe650000' missing or empty
[  17.249601] Bluetooth: hci0: command 0xfc18 tx timeout
[  25.313669] Bluetooth: hci0: BCM: failed to write update baudrate (-110)
[  25.314303] Bluetooth: hci0: Failed to set baudrate
[  27.329634] Bluetooth: hci0: command 0x0c03 tx timeout
[  35.553614] Bluetooth: hci0: BCM: Reset failed (-110)
Armbian 23.02.0-trunk.0027 Jammy ttyS2
quartz64a login: root
Password:
____  _              ___                  _        __  _  _        _
|  _ \(_)_ __  ___  / _ \ _  _  __ _ _ __| |_ ____/ /_ | || |      / \
| |_) | | '_ \ / _ \ | | | | | | |/ _` | '__| __|_  / '_ \| || |_    / _ \
|  __/| | | | |  __/ | |_| | |_| | (_| | |  | |_ / /| (_) |__  _|  / ___ \
|_|  |_|_| |_|\___|  \__\_\\__,_|\__,_|_|  \__/___|\___/  |_|  /_/  \_\
Welcome to Armbian 23.02.0-trunk.0027 Jammy with bleeding edge Linux 6.0.12-media
No end-user support: untested automated build
System load:  2%              Up time:      5 min
Memory usage:  4% of 3.65G      IP:
CPU temp:      45°C            Usage of /:    7% of 29G
RX today:      7.3 MiB
[ 5 security updates available, 8 updates total: apt upgrade ]
Last check: 2022-12-14 22:20
root@quartz64a:~#
Angry
solved on latest build
Armbian_23.02.0-trunk.0048_Quartz64a_jammy_edge_6.1.0.img
  Has anyone tried Ubuntu 22.04 server yet? 98cwitr 2 6,504 06-12-2022, 03:31 AM
Last Post: Peter Gamma
