RK3566 debug component clarification.
So I've been debugging various things on my RK3566 based soquartz and standard debugging is becoming insufficient for my needs. Hardware tracing would be really nice to have and there is Coresight ETM support in Linux.
However before I spend lots of time trying to get it working can someone clarify for me if RK3566 actually has a functioning Coresight ETM component? If yes, is it version ETMv4 and what subcomponents it has(trace funnel? anything else)?
The RK3568 (that is supposedly very similar to rk3566) TRM document claims rk3568 has DAP-Lite2 debug component which is described on ARM;s website as "a simple debug component with no tracing capability."
So if there is no tracing capability why does the ROM table contain tracing components for each CPU? (listing below)
AP # 0x0 AP ID register 0x24770002 Type is MEM-AP APB2 or APB3 MEM-AP BASE 0x80000003 Valid ROM table present Component base address 0x80000000 Peripheral ID 0x0000080000 Designer is 0x000, <invalid> Part is 0x000, Unrecognized Component class is 0x1, ROM table MEMTYPE system memory not present: dedicated debug bus ROMTABLE[0x0] = 0x01000003 Component base address 0x81000000 Peripheral ID 0x04007bb4e3 Designer is 0x23b, ARM Ltd Part is 0x4e3, Unrecognized Component class is 0x9, CoreSight component Type is 0x00, Miscellaneous, other Dev Arch is 0x47700af7, ARM Ltd "CoreSight ROM architecture" rev.0 Type is ROM table MEMTYPE system memory not present: dedicated debug bus [L01] ROMTABLE[0x0] = 0x00001006 Component not present [L01] ROMTABLE[0x4] = 0x00002006 Component not present [L01] ROMTABLE[0x8] = 0x00004003 Component base address 0x81004000 Peripheral ID 0x04003bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x15, Debug Logic, Processor Dev Arch is 0x47708a15, ARM Ltd "Processor debug architecture (v8.2-A)" rev.0 [L01] ROMTABLE[0xc] = 0x00005003 Component base address 0x81005000 Peripheral ID 0x04003bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x15, Debug Logic, Processor Dev Arch is 0x47708a15, ARM Ltd "Processor debug architecture (v8.2-A)" rev.0 [L01] ROMTABLE[0x10] = 0x00006003 Component base address 0x81006000 Peripheral ID 0x04003bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x15, Debug Logic, Processor Dev Arch is 0x47708a15, ARM Ltd "Processor debug architecture (v8.2-A)" rev.0 [L01] ROMTABLE[0x14] = 0x00007003 Component base address 0x81007000 Peripheral ID 0x04003bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x15, Debug Logic, Processor Dev Arch is 0x47708a15, ARM Ltd "Processor debug architecture (v8.2-A)" rev.0 [L01] ROMTABLE[0x18] = 0x00008002 Component not present [L01] ROMTABLE[0x1c] = 0x00009002 Component not present [L01] ROMTABLE[0x20] = 0x0000a002 Component not present [L01] ROMTABLE[0x24] = 0x0000b002 Component not present [L01] ROMTABLE[0x28] = 0x0000c003 Component base address 0x8100c000 Peripheral ID 0x04003bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x16, Performance Monitor, Processor Dev Arch is 0x47702a16, ARM Ltd "Processor Performance Monitor (PMU) architecture" rev.0 [L01] ROMTABLE[0x2c] = 0x0000d003 Component base address 0x8100d000 Peripheral ID 0x04003bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x16, Performance Monitor, Processor Dev Arch is 0x47702a16, ARM Ltd "Processor Performance Monitor (PMU) architecture" rev.0 [L01] ROMTABLE[0x30] = 0x0000e003 Component base address 0x8100e000 Peripheral ID 0x04003bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x16, Performance Monitor, Processor Dev Arch is 0x47702a16, ARM Ltd "Processor Performance Monitor (PMU) architecture" rev.0 [L01] ROMTABLE[0x34] = 0x0000f003 Component base address 0x8100f000 Peripheral ID 0x04003bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x16, Performance Monitor, Processor Dev Arch is 0x47702a16, ARM Ltd "Processor Performance Monitor (PMU) architecture" rev.0 [L01] ROMTABLE[0x38] = 0x00014003 Component base address 0x81014000 Peripheral ID 0x04007bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x14, Debug Control, Trigger Matrix Dev Arch is 0x47701a14, ARM Ltd "Cross Trigger Interface (CTI) architecture" rev.0 [L01] ROMTABLE[0x3c] = 0x00015003 Component base address 0x81015000 Peripheral ID 0x04007bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x14, Debug Control, Trigger Matrix Dev Arch is 0x47701a14, ARM Ltd "Cross Trigger Interface (CTI) architecture" rev.0 [L01] ROMTABLE[0x40] = 0x00016003 Component base address 0x81016000 Peripheral ID 0x04007bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x14, Debug Control, Trigger Matrix Dev Arch is 0x47701a14, ARM Ltd "Cross Trigger Interface (CTI) architecture" rev.0 [L01] ROMTABLE[0x44] = 0x00017003 Component base address 0x81017000 Peripheral ID 0x04007bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x14, Debug Control, Trigger Matrix Dev Arch is 0x47701a14, ARM Ltd "Cross Trigger Interface (CTI) architecture" rev.0 [L01] ROMTABLE[0x48] = 0x0001c003 Component base address 0x8101c000 Peripheral ID 0x04003bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x13, Trace Source, Processor Dev Arch is 0x47724a13, ARM Ltd "Embedded Trace Macrocell (ETM) architecture" rev.2 [L01] ROMTABLE[0x4c] = 0x0001d003 Component base address 0x8101d000 Peripheral ID 0x04003bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x13, Trace Source, Processor Dev Arch is 0x47724a13, ARM Ltd "Embedded Trace Macrocell (ETM) architecture" rev.2 [L01] ROMTABLE[0x50] = 0x0001e003 Component base address 0x8101e000 Peripheral ID 0x04003bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x13, Trace Source, Processor Dev Arch is 0x47724a13, ARM Ltd "Embedded Trace Macrocell (ETM) architecture" rev.2 [L01] ROMTABLE[0x54] = 0x0001f003 Component base address 0x8101f000 Peripheral ID 0x04003bbd05 Designer is 0x23b, ARM Ltd Part is 0xd05, Unrecognized Component class is 0x9, CoreSight component Type is 0x13, Trace Source, Processor Dev Arch is 0x47724a13, ARM Ltd "Embedded Trace Macrocell (ETM) architecture" rev.2 [L01] ROMTABLE[0x58] = 0x00000002 Component not present [L01] ROMTABLE[0x5c] = 0x00000002 Component not present
It is clear we have a CTI, a PMU and an ETM for each core. Can anyone confirm/deny if those can be made to work?
BTW. If anyone is interested how to do hardware level debug on Quartz64 I wrote a quick description here: http://notes.zahoryzontnik.com/
  RK3566 Memory map Gridley 2 8,076 07-25-2022, 04:37 AM
Last Post: Gridley
  Does RK3566 support s2ram deep sleep? jag 0 3,274 09-27-2021, 12:16 PM
Last Post: jag
