Portfolio not extracting ZIPs any more
Like the title says. This worked fine for quite a while.
Today I flashed tow-boot to emmc and reinstalled mobian.
Now, Portfolio doesn't extract zip files any more ("Could not open <filename>.zip").
Unzipping in the terminal works.
I wanted to uninstall and reinstall but unfortunately, uninstalling Portfolio isn't possible  in "Software" ("Unable to remove Portfolio: no packages to remove"). I also can't find a target for apt remove.
Does someone have an idea how I could fix the zip function or how I could uninstall Portfolio? Maybe the flathub version works better...?
Portfolio was quite usable on the Pinephone and fulfilled all my needs. I just want it to work like it did before the reinstallation.
Thanks in advance
