PPP won't charge
(01-30-2022, 12:57 AM)bcnaz Wrote: Did you remove the tape from the battery ?
Yes I did.
Update I did get it to update using
Sudo rm /var/lib/pacman/db.lck
Command then run
Sudo pacman -Syyu
Command.
It updated perfect and is charging now. The battery still drains quickly but I'm hoping after some use it will get better or as I explore more I'll find some better settings for battery life.
PPP won't charge - by Frost1776 - 01-29-2022, 10:08 PM
RE: PPP won't charge - by bcnaz - 01-30-2022, 12:57 AM
RE: PPP won't charge - by Frost1776 - 01-30-2022, 01:35 AM
RE: PPP won't charge - by bcnaz - 01-30-2022, 01:45 AM
RE: PPP won't charge - by Frost1776 - 01-30-2022, 01:49 AM
RE: PPP won't charge - by bcnaz - 01-30-2022, 02:07 AM
RE: PPP won't charge - by trekkie1701c - 01-30-2022, 09:02 AM
RE: PPP won't charge - by Truemmerer - 01-30-2022, 11:08 AM
RE: PPP won't charge - by captainmorgan - 01-30-2022, 01:46 PM
RE: PPP won't charge - by Frost1776 - 01-30-2022, 03:18 PM
RE: PPP won't charge - by Frost1776 - 01-30-2022, 11:19 PM
