Help how to mount SD-Card
(11-19-2021, 05:01 AM)wibble Wrote: Before moving on to an fstab entry you need to make sure you can mount the partition manually, which it seems you can't do yet. I suspect that's because the partition isn't vfat. There are several ways you can check which filesystem type it's using - I'm not sure which will be present by default on PmOS but here are some you can try:
lsblk -f
blkid /dev/mmcblk0p2
sudo file -sL /dev/mmcblk0p2
These will also show you the UUID of the partition - this is what should go in the fstab entry, not the disk identifier you used.
Hi wibble,
Thanks for your reply. The mmcblk0p2's UUID clearly are different than what I thought it was after digging deeper into the device.
However, after probing into the mmcblk0p2, the type return with "dos". Other than 'vfat' or ext4, pmOS does not seems to know others type of format. I tried "ntfs" "ntfs-3g" for types which return unknown filetype. Is there a package that I needed to install first before it can read the filetype?
Cheers,
Chadwick
(11-20-2021, 03:31 AM)Juergen Wrote:
(11-19-2021, 04:09 AM)chadwick Wrote: Hi All,
On a linux desktop, one way to access your device is to edit the "/etc/fstab" to mount your device permanently so you can access it.
Reading postmarketOS's wiki about fstab, it told you to activate "rc-update" and the localmount service, which is the command:
sudo rc-update add localmount default
And to check whether the service is running:
rc-service localmount status
While blkid will return nothing, I use "sudo fdisk -l" to identify the UUID of the SD-Card, which gives:
Disk /dev/mmcblk0: 59.48 GiB, 63864569856 bytes, 124735488 sectors
Disklabel type: gpt
Disk identifier: Disk /dev/mmcblk0: 59.48 GiB, 63864569856 bytes, 124735488 sectors
Disklabel type: gpt
Disk identifier: DC11BA49-9C6F-4BC0-B775-E39576550622
Device           Start       End   Sectors  Size Type
/dev/mmcblk0p1    2048   1050623   1048576  512M EFI System
/dev/mmcblk0p2 1050624 124733439 123682816   59G Microsoft basic data
Therefore, I edit my fstab to looks like the following:
UUID=DC11BA49-9C6F-4BC0-B775-E39576550622 /home/user/SDCard vfat defaults 0 0
On a reboot it did not give me anything in the folder. Upon the failure, I tried to mount the SDcard by using the mount command, which return error:-
sudo mount -t vfat -o ro /dev/mmcblk0p2 ~/SDCard
mount: /home/user/SDCard: wrong fs type, bad option, bad superblock on /dev/mmcblk0p2, missing codepage or helper program, or other error.
My question is, is there something wrong with what I did or anything that I might not have been aware of?
Cheers.
Chadwick
for me this worked:
sudo passwd
sudo blkid /dev/null >uuid.txt
edit
/etc/fstab
UUID= .....   /home/user/SDCard vfat defaults 0 0
sudo chmod 777 ~/SDCard
Hi Juergen,
Thank you for your reply. Would you mind elaborate a bit more, I do not see how that would help pmOS to read the SDCard that is format as 'dos' filetype.
Cheers
Chadwick
Help how to mount SD-Card - by chadwick - 11-19-2021, 04:09 AM
RE: Help how to mount SD-Card - by wibble - 11-19-2021, 05:01 AM
RE: Help how to mount SD-Card - by chadwick - 11-22-2021, 12:46 AM
RE: Help how to mount SD-Card - by Juergen - 11-20-2021, 03:31 AM
RE: Help how to mount SD-Card - by wibble - 11-22-2021, 07:02 AM
RE: Help how to mount SD-Card - by chadwick - 11-25-2021, 03:37 AM
RE: Help how to mount SD-Card - by wibble - 11-25-2021, 09:15 AM
RE: Help how to mount SD-Card - by chadwick - 11-26-2021, 05:09 AM
RE: Help how to mount SD-Card - by chadwick - 11-30-2021, 11:12 PM
  How can I get the permissions to write to the external SD card ...? Peter Gamma 9 1,711 10-20-2023, 12:32 PM
Last Post: Peter Gamma
  How to write the the external SD card with Abword? Peter Gamma 0 450 08-27-2023, 01:10 AM
  How can I open an Abiword file from an external SD card with Abiword? Peter Gamma 5 2,031 08-25-2023, 02:05 AM
  Unable to mount root partition PostmarketOS lanawwas 0 2,876 09-06-2020, 07:42 AM
Last Post: lanawwas
  pmaports root & boot mount issue dustfinger 0 1,983 07-07-2020, 09:43 AM
Last Post: dustfinger
  PP boots into factory test even if flashed sd card is inserted hapster 5 6,478 04-13-2020, 02:34 PM
Last Post: MartijnBraam
  terminal command for sd card size pnphn 5 6,713 04-02-2020, 12:51 PM
Last Post: someGermanGuy
