Armbian on the PinePhone
I have successfully run Armbian on the PinePhone. It actually runs quite well. Aside from minor glitches, everything works. Even the modem started!
How to do it:
1. Get the kernel modules and kernel of your currently installed OS. Also get the U-Boot bootloader for the PinePhone.
2. Get an image of Armbian for the OG Pinebook and write it to the emmc/SD.
3. Write the U-Boot image to the SD Card/emmc.
4. Replace the kernel of the installed Armbian image on the emmc/SD with the one you got from your installed OS.
5. Add the kernel modules that you have to the /lib/modules directory of your Armbian image.
6. Reboot the PinePhone and it should boot into Armbian. Do not upgrade the kernel from apt unless you are going to replace it again.
  Axolotl on PinePhone / Mobian arno_nuehm 119 33,575 Today, 01:58 AM
Last Post: arno_nuehm
  Mobian pinephone -- "Stalled" (best way to describe it) fred_mobian 3 146 09-24-2021, 08:19 PM
Last Post: bcnaz
  Pure Maps GPS on Pinephone Mobian godzillest 3 613 08-03-2021, 03:07 AM
Last Post: mouffa
  Axolotl on Pinephone CarmeloLabadie 1 374 07-26-2021, 12:56 AM
Last Post: kqlnut
  Best/easiest way to install minimal Debian on PinePhone? mcgee 6 796 07-18-2021, 09:35 AM
Last Post: swiley
  Pinephone in Canada using Shaw mobile provider RRman 0 332 06-19-2021, 06:35 PM
Last Post: RRman
  Reboot Modem on Pinephone in Mobian eggmatters 5 1,709 06-17-2021, 02:08 PM
Last Post: eggmatters
  Pinephone ”reboot” or logging out by itself Wahtone 0 352 05-28-2021, 09:32 AM
Last Post: Wahtone
  mobian, pinephone camera, and megapixels dawg161 34 7,246 05-01-2021, 02:34 PM
Last Post: NormandC
  How do I install pinephone-devtools? lsitongia 1 771 04-06-2021, 04:31 PM
Last Post: dukla2000
