Mobian not updating via Software app
Pinephone
Mobian OS
Debian Gnu/Linux bullseye/sid
64-bit
Gnome Version 3.38.4
Wayland
I have Mobian installed on my Pinephone and it is not updating or allowing me to update it via software app. When trying to refresh it says it cannot get it. If I can not update it, does it mean I will have to do a clean install of Mobian every time a new version comes out? I have not updated it since around May 5th of 2021.
have you tried to ssh into the phone and run sudo apt update && sudo apt upgrade?
(06-07-2021, 09:40 AM)tophneal Wrote: have you tried to ssh into the phone and run sudo apt update && sudo apt upgrade?
That's what I always do. The Mobian GUI software application has never really worked as far as I know.
(06-07-2021, 06:52 AM)FOSSagent0 Wrote: Pinephone
Mobian OS
64-bit
Wayland
I think I kind of had that problem but it fixed when I reinstalled mobian. I have updated from the software center several times and it seems to work. all repos are open besides 'linux vendor firmware'. It says ive got Debian 11 and gnome 3.38.5
have you tried to install something like Wireguard? that killed it for me.
Out of curiousity, why ssh into it instead of just firing up terminal and running the sudo apt commands on the phone itself?
Just personal preference. Either works. I just haven’t had a good touch screen experience in terminals.
  Mobian repository status henrythemouse 1 35 26 minutes ago
  Axolotl on PinePhone / Mobian arno_nuehm 105 27,228 Yesterday, 01:20 PM
  Wipe function on mobian? Wahtone 4 267 07-21-2021, 09:55 AM
Last Post: e-minguez
  Dark theme (on Mobian)? TRS-80 6 286 07-14-2021, 01:35 PM
  (Gnome) Maps won't start on Mobian? TRS-80 3 215 07-11-2021, 12:09 PM
Last Post: TRS-80
  Mobian Constant Vibration tumblingdog 4 782 07-10-2021, 02:40 AM
Last Post: aed
  Update-rc.d for Mobian Davio 2 268 06-27-2021, 08:34 AM
Last Post: Davio
  Reboot Modem on Pinephone in Mobian eggmatters 5 1,031 06-17-2021, 02:08 PM
Last Post: eggmatters
  mobile data on mobian not working synaption 1 325 06-02-2021, 03:16 PM
Last Post: Aberts10
  How do you copy and paste into mobian terminal? Do you ssh instead? temp0rary 6 549 06-01-2021, 12:16 PM
Last Post: temp0rary
