Telegran connection problems
Hi all
I have Mobian installed on a pinephone 64 and most things work fine for me as I don't really ask a phone to do that much.  I have Telegram up and running but have the following problem.
I can connect to Telegram via wifi (modem/router) at home where I have no mobile connection without an issue.  When I get into mobile range the connection will initially be fine and then without doing anything to the phone (I don't turn it off or even make a call) it will lost connectivity.  It will get into an endless cycle of trying to reconnect and no amount of restarting or whatever will help.  It is important to say that it will be initially be connected to the mobile network and works fine but then drops out.  If I leave it, not connected and trying to reconnect, and then drivehome and losing mobile coverage the phone automatically connects to the modem which it always does and then Telegram is fine again.
I've searched the forums in debian but I can't find anything addressing this issue.  Does anybody have similar experiences or a fix/suggestion for this?
Thanks for any help.
  Stability problems with 6.1 kernel Zebulon Walton 9 10,838 05-12-2023, 08:09 AM
Last Post: zetabeta
  DNS Problems with Mobile Data arno_nuehm 29 41,289 10-29-2022, 09:16 AM
Last Post: treebeard
  Problems after Tow-Boot Dinosaur1946 3 5,114 09-18-2022, 12:48 AM
Last Post: SpaggettiCoder
  Will this battery-saving script cause problems? rp3 1 3,973 08-28-2022, 02:00 PM
  Tow-boot problems and restoring uboot Zebulon Walton 15 20,523 08-14-2022, 11:09 AM
Last Post: shulamy
  SMS quit - "Lost dbus connection" 98cwitr 0 2,053 06-09-2022, 06:42 AM
Last Post: 98cwitr
  Browser cog - Problems on Mobian arno_nuehm 5 9,789 02-10-2022, 03:27 PM
Last Post: pothos
  ARM Microsoft Teams-problems installing eaglebeckley 15 28,176 01-14-2022, 01:59 AM
Last Post: Tazdevl
  rsyslog a bad idea? Problems with ssh, openssh-server, fail2ban Anna 7 11,726 11-14-2021, 06:20 PM
Last Post: juju
Bug PulseAudio: connection terminated/daemon killed Zombie Feynman 0 3,100 08-24-2021, 09:48 AM
Last Post: Zombie Feynman
