05-11-2021, 04:12 PM
I've been grinding away after 23 years away from Unix trying to 86 windows from my life.
So Far I've got Armbian/Ubuntu/Mate working overcoming various issues along the way.
This is a solid 6 days now and I'm stuck so if someone could point me in the right direction I'd really appreciate it....
I'm using an iiyama E2783QSU on HDMI-1, and trying new modes using xrandr
After getting seriously bored manually going through the options I wrote a little script to help.....
Usage is therefore...
The current mode is...
but if I try to create a duplicate mode or a higher res mode I just get an error but as you can see below "gtf" is not creating a matching mode to the current one that is working....
All the tests I have done 60 odd in total all fail with
I am probably doing something obvious wrong but to be fair I am now losing the will to live
If anyone can help point me in the right direction on this extensive voyage of discovery I would really really appreciate it. :pray:
text=$(gtf $1 $2 $3)
search="\""
rest=${text#*$search}
rest=${rest#*$search}
xrandr --newmode $4 $rest
xrandr --addmode HDMI-1 $4
xrandr --output HDMI-1 --mode $4Usage is therefore...
bash x.sh 1920 1080 60 "test-0001"The current mode is...
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 4096 x 4096
HDMI-1 connected primary 1920x1080+0+0 (0x43) normal (normal left inverted right x axis y axis) 597mm x 336mm
Identifier: 0x41
Timestamp: 204213
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0026cd1e66cd050000
081c0103803c2278eaa191a65650a026
0d5054254b009500a9c0a900a940b300
d1c0d100e100565e00a0a0a029503020
350055502100001a000000ff00313134
33313830383131343835000000fd0032
4b1e591b000a202020202020000000fc
00504c32373833510a2020202020011e
020322f14f1005040302011112131406
0715161f230907078301000065030c00
1000023a801871382d40582c45005550
2100001e011d8018711c1620582c2500
55502100009e011d007251d01e206e28
550055502100001e8c0ad08a20e02d10
103e9600555021000018000000000000
000000000000000000000000000000cd
max bpc: 0
range: (8, 16)
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 49
supported: 49
non-desktop: 0
range: (0, 1)
1920x1080 (0x43) 148.500MHz +HSync +VSync *current
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hzbut if I try to create a duplicate mode or a higher res mode I just get an error but as you can see below "gtf" is not creating a matching mode to the current one that is working....
test-0001 (0x25e) 172.800MHz -HSync +VSync
h: width 1920 start 2040 end 2248 total 2576 skew 0 clock 67.08KHz
v: height 1080 start 1081 end 1084 total 1118 clock 60.00HzAll the tests I have done 60 odd in total all fail with
xrandr: Configure crtc 0 failedI am probably doing something obvious wrong but to be fair I am now losing the will to live
