New screen, now cant make calls
Hi all;
I dropped my phone a while back, I got a replacement screen and installed it myself. First time on any phone...
I put it back together and the modem doesn't appear to be working, have reinstalled mobian, I have signal strength, but not registered on the network. Everything else seems to work WiFi is good.
Have tried different sim card, no change, sim works on other phone.
Is there anything I can do to narrow the fault down to software or hardware ?
I guess I must have stuffed the main board somehow when I pulled it apart, but it would be good if I could confirm it.
(03-14-2021, 08:23 AM)bug1 Wrote: Hi all;
If you are showing signal bars double check your carrier and APN settings. They may have changed and you lost voLTE because of the change.
(03-14-2021, 08:36 AM)C0ffeeFreak Wrote: If you are showing signal bars double check your carrier and APN settings. They may have changed and you lost voLTE because of the change.
Im starting to think your right, maybe it was just a coincidence wit hme changing the screen, and its software related.
The previous sim i tried was from the same network provider, so it probably wasnt a good test of the sim. I got a new sim today for a different network, it still doesnt see a network, but it has given me a new list of APNs to choose from, so something is going on, will treat it as software problem, and use command line to find an error message...
Thanks for your reply.
  My Phone stopped making and recieving Calls tracyanne 0 11,454 09-14-2025, 03:30 PM
Last Post: tracyanne
  Screen dying already? marcih 156 308,530 06-12-2025, 06:18 AM
Last Post: mikeb
  Screen Replacement Instructions erikkugel 5 12,330 02-24-2025, 06:55 AM
Last Post: anonymous
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 2,084 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 6,805 10-12-2023, 01:03 PM
Last Post: robthebold
  No calls in or out on beta IsaiahSp 0 2,344 09-28-2023, 10:44 PM
Last Post: IsaiahSp
  No calls on Pine Phone Beta convergence edition polypode 1 3,802 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  I cannot call or receive calls aka0kuro 6 9,846 01-13-2023, 05:31 PM
Last Post: alaraajavamma
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 8,767 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 4,779 07-03-2022, 06:27 AM
Last Post: Avisando
