issues after recent updates
a few issues popped up after last nights updates.
1. sxmo_setpinebacklight segfults unless it is run with sudo, therefore adjustong brightness with the config menu or in xinitrc fails and just displays the default brightness of 750.
2. suspend and lock (screen off) both turn off the screen for a second or so and then turn it back on. it appears that suspend is completely broken
this is all ive noticed so far but its been a busy work week
Do any of the sxmo developers read this subforum and take action based on reports here, or have you had to make bug reports on their site in order to make anything happen? It seems very quiet here.
To answer @desca's question: https://forum.pine64.org/showthread.php?tid=13102
@hiimtye to fix your issue, try running
sudo rc-update add sxmo-pinephone default
and rebooting your pinephone.
(02-13-2021, 01:33 PM)anjanmomi Wrote: To answer @desca's question: https://forum.pine64.org/showthread.php?tid=13102
We just released 1.3.1 that should fix this issue (don't forget to reboot): https://lists.sr.ht/~mil/sxmo-announce/%...roy.lxd%3E
issues are fixed after todays updates
