USB dock - ethernet access
Hey there,
got my Pinephone with KDE today and I managed to get a lot of stuff working so far reading through the forum. Now I have come across some issues with the dock. I don't need to set it up for desktop use but I wanna use the ethernet port because I don't have WLAN access in my flat.
Out of the box it did not work at all. The phone did not show up in my router and I got no access to the internet. After I updated the packages I get it to connect to the wired LAN and it even shows up in my router but the connection is dropped a few seconds later. Is there any known solution to this ? I am not even sure if it is the phone because I also happened to get a new router just yesterday and it had some issues with my desktop Manjaro OS.
I also read about connecting the dock to a power source or not. Is there something I am missing with the dock ?
Cheers
(01-30-2021, 08:12 AM)Regula Wrote: Hey there,
Cheers
Ok, issue is gone after I installed the new Manjaro Phosh release. I guess it was caused by KDE mobile. For future posts, is there some way to edit your posts ?
Glad your issue is solved. I had to run the scripts manually to reconnect to the internet. Ethernet wasn't working on the USB-C dock. I asked on the official Manjaro support
website.
  Compatible U.S. carriers with web voicemail access? Zebulon Walton 2 5,028 08-15-2025, 07:34 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,941 01-09-2024, 07:02 PM
Last Post: britelite
Lightbulb pinephone mobile dock jasmin763 2 4,319 06-06-2022, 09:06 AM
Last Post: 98cwitr
  No data access on ATT prepaid but my plan has data dc2daylight 6 12,696 04-03-2022, 02:14 PM
Last Post: dc2daylight
  ethernet connection using usb-C gilwood 1 3,883 12-25-2021, 10:13 AM
Last Post: gilwood
  Is there any risk in plugging the PinePhone into a powered Thunderbolt dock? Mark53 2 6,123 10-27-2020, 03:32 PM
Last Post: Mark53
  USB C dock - hdmi adventure murak 7 16,298 09-26-2020, 11:39 AM
Last Post: jmorris
  Which is the easiest way to access the external SD card of a Pinephone from a PC? Peter Gamma 7 11,945 06-16-2020, 08:38 AM
Last Post: Peter Gamma
