A terminal window never opens in Chromiun OS
hi, im trying to set up Linux (Beta) on my rockpro64, my Chromium OS version is 76.0.3809.52 (official build) (32 bit). I am following the steps of the url: https://support.google.com/chromebook/an...?hl=es-419 but step 5 is never executed.
i restart my rockpro, and im check that my virtual machine is up to date, but always when i select check for update Under 'cros-termina', I always get the same message  'Status - Component not updated'
Is there any way to fix this bug?
Regards, and thank you very much
Can anyone tell me what might be happening? I would like to use this OS but I can't install anything on it
It seems that i enabled Linux Beta, but when I try to start it it won't start, just the spinning white circle before disappearing from the app shelf, and I don't get any error message
what happens when you run the installer through settings?
considering it uses the same, or a very similar image to the PBP, i'm afraid you may not get a working crostini shell. you likely will need to install crouton (though x forwarding with the plugin likely also wont work.
Not sure if it will work, but you could try flashing the fyde img to an sd and seeing if that boots. it has working crostini and android+play store.
(01-13-2021, 12:38 PM)tophneal Wrote: what happens when you run the installer through settings?
Hello, thanks for response, really i think think that I haven't gotten to install it correctly because when i executing 'vmc list' in Chrome OS developer shell i receive this response:
termina (0 bytes)
Total Size (bytes): 0
and if i execute 'vmc start termina' i receive this response:
Error: routine at frontends/vmc.rs:133 `vm_start(vm_name,user_id_hash,VmFeatures{gpu:matches.opt_present("enable-gpu"),software_tpm:matches.opt_present("software-tpm"),})` failed: bad VM status: `VM_STATUS_FAILURE`: VM failed to start in time
but terminal apears in app menu, and if i click in the icon, the terminal never opens. I'll try to do what you told me.
