Need a working copy of pacman.conf
Hello. Pretty simple issue.
I borked my own conf file, and I don't see any other place to get a new one.
I think I need pamac.conf as well.
so if someone could just upload those that would be awesome.
i'm not going to be specific:
using following command, i get following:
$ man pacman-mirrors
DESCRIPTION        Generates  mirrorlist  with  up-to-date  mirrors for Manjaro Linux.  Default is to rank all mirrors by reponse time.  If no arguments are given pacman-mirrors lists available options.  Pacman-mirrors requires access to files        which are read-only so it must be run with su or sudo.        To create a mirrorlist using all default use               pacman-mirrors -f        The mirrorlist generation process can be refined through arguments and arguments with options, for example               pacman-mirrors --country Denmark --timeout 5 IMPORTANT        After all operations ALWAYS syncronize and update your system with               sudo pacman -Syyu OPERATION        Pacman-mirrors tries to provide ONLY up-to-date mirrors if they are available in your chosen mirror pool.  This means - at any given time - the number of available mirrors will vary depending on when  the  mirror  last  syn‐        cronized with the master repo server.  If no up-to-date mirrors is available in your chosen mirror pool, your mirror list will not be changed.  This behavior can be overridden if so desired by using the -s/–no-status switch.
i don't think your system is totally borked, so this might fix the problem.
and here for more info, https://wiki.manjaro.org/index.php/Main_Page
There is a pacman.conf here: https://gist.github.com/setkeh/4221991
and a pamac.conf here: https://github.com/manjaro/pamac/blob/ma...pamac.conf
  Outbound sms not working Stubb 0 2,447 12-18-2022, 10:00 PM
Last Post: Stubb
Sad Modem is always visible/connected but stops working after a while dante404 6 8,644 11-08-2022, 09:12 AM
Last Post: dante404
  HowTo: Get a passcode from DUO Mobile working on the Pinephone kop316 2 7,366 01-16-2022, 03:46 PM
Last Post: michel_luc
  4G not working properly Calamity 2 5,289 02-02-2021, 12:00 PM
Last Post: Calamity
  After installing CRUST, what does a distro need to do to get wake on modem working? Subsentient 4 10,747 07-06-2020, 04:32 AM
Last Post: Alefnode
  Touch Screen not working mjoconr 1 4,799 05-09-2020, 09:28 PM
Last Post: Subsentient
