I want to to use the H64 B as a desktop...surfing the web and e-mail, etc.
I want to try Trisquel Mini ( 1.2 GB) with at least 64 GB eMMC. I "Think" it should work as Ubutu supposedly works, and Trisquel is the more secure version of Ubuntu...
Any advice?
Thanks!
I would rather say the difference is rather big. In the end, it's the difference between using a rolling distro or a "frozen" one like Debian/Ubuntu. Personally, I prefer the latter as I like to have a system that - once I got it working - keeps working and does not occasionally break after updates. If you are more on the edgy side and want to have the newest stuff, a rolling distro might be the better option. Also, when running on not-so-well-supported hardware (like the PINE-H64) hardware support might be a lot better.
Yet, I think that it's pretty feasible to run the H6 with the combination of Debian stable and an unstable kernel (eventually using a usb-ethernet-adapter if the driver makes trouble). The upcoming Debian 11 version (bullseye) should have better support for the H6, although I doubt it will officially support it ootb.
proper Manjaro support would be nice as it supports many other PINE devices fairly well.
it doesn't get happy
it doesn't get sad
it just runs programs
