high pitched noise / coil whine?
Hello forum.
Is anyone else hearing a high pitched pulsing sound from their pine? I suspect coil whine, which is annoying, but can't really be much done about. But if that is true, there should be more people experiencing the same thing.
don't get mine til later but do you have wifi/ bluetooth?
yes i do, but it actually doesnt make a difference if the module is there or not.
