Wish List
[img]chrome-extension://hiidjliailpkjeigakikbfedlfijngih/images/right-arrow.png[/img]
Hello World..
Is there a way to make a wifi hotspot in manjara ARM on pinephone?
And a protonmail client?
And the Geary is still not working..
Any solutions?
Zeven
Regarding protonmail, I have successfully rebuilt the protonmaill bridge in nogui mode, and was able to get my protonmail email from geary (I built it myself from geary's github, the one pre installed segfaults...)
in order to have usb tethering, you need those two scripts:
pinephone-setup-usb-nework.sh:
#!/bin/sh if [ ! -e /etc/NetworkManager/system-connections/USB.nmconnection ]; then     # Create network connection     nmcli connection add con-name USB \                         ifname usb0 \                         type ethernet \                         ip4 10.66.0.1/8     # Set priorities so it doesn't take precedence over WiFi/mobile connections     nmcli connection modify USB ipv4.route-metric 1500     nmcli connection modify USB ipv4.dns-priority 150     # Share connection so it can be used for tethering     nmcli connection modify USB ipv4.method shared fi
and, pinephone-usb-gadget.sh:
#!/bin/sh CONFIGFS=/sys/kernel/config/usb_gadget/g1 USB_VENDORID="0x1D6B"  # Linux Foundation USB_PRODUCTID="0x0104" # Multifunction composite gadget USB_MANUF="Mobian Project" USB_PRODUCT="Mobian" USB_SERIAL=`cat /etc/machine-id` setup() {     # Don't do anything if the USB gadget already exists     #[ -d $CONFIGFS ] && exit 0     # Required to make a composite gadget     modprobe libcomposite     # Create all required directories     echo "Creating the USB gadget..."     mkdir -p $CONFIGFS     mkdir -p $CONFIGFS/strings/0x409     mkdir -p $CONFIGFS/configs/c.1     mkdir -p $CONFIGFS/configs/c.1/strings/0x409     # Setup IDs and strings     echo "Setting up gadget strings..."     echo $USB_VENDORID > $CONFIGFS/idVendor     echo $USB_PRODUCTID > $CONFIGFS/idProduct     echo $USB_MANUF > $CONFIGFS/strings/0x409/manufacturer     echo $USB_PRODUCT > $CONFIGFS/strings/0x409/product     echo $USB_SERIAL > $CONFIGFS/strings/0x409/serialnumber     # Create ECM (ethernet) function     echo "Adding ECM function..."     mkdir $CONFIGFS/functions/ecm.usb0     # TODO: create RNDIS function for Windows compatibility     # Create MTP using FunctionFS     # echo "Adding MTP function using FunctionFS..."     # mkdir $CONFIGFS/functions/ffs.mtp     # Create configuration     echo "Creating gadget configuration..."     echo "Ethernet" > $CONFIGFS/configs/c.1/strings/0x409/configuration     # echo "Ethernet + MTP" > $CONFIGFS/configs/c.1/strings/0x409/configuration     ln -s $CONFIGFS/functions/ecm.usb0 $CONFIGFS/configs/c.1     # ln -s $CONFIGFS/functions/ffs.mtp $CONFIGFS/configs/c.1     # Mount the MTP FunctionFS     # echo "Mounting FunctionFS..."     # mkdir -p /dev/ffs-mtp     # mount -t functionfs mtp /dev/ffs-mtp } start() {     echo "Enabling the USB gadget..."     sleep 1     UDC=`ls /sys/class/udc`     echo "$UDC" > $CONFIGFS/UDC } reset() {     echo "Removing the USB gadget..."     # Remove USB gadget     if [ -d $CONFIGFS ]; then         echo "Removing gadget configuration..."         # rm $CONFIGFS/configs/c.1/ffs.mtp         rm $CONFIGFS/configs/c.1/ecm.usb0         rmdir $CONFIGFS/configs/c.1/strings/0x409/         rmdir $CONFIGFS/configs/c.1/         # rmdir $CONFIGFS/functions/ffs.mtp         rmdir $CONFIGFS/functions/ecm.usb0         rmdir $CONFIGFS/strings/0x409/         rmdir $CONFIGFS     fi     # Unmount FunctionFS and delete its mount point     # if [ -d /dev/ffs-mtp ]; then     #    echo "Unmounting FunctionFS..."     #    umount /dev/ffs-mtp     #    rmdir /dev/ffs-mtp     #fi } case "$1" in     reset) reset ;;     setup) setup ;;     start) start ;;     *) ;; esac
then run:
sudo ./pinephone-setup-usb-nework.sh sudo ./pinephone-usb-gadget.sh reset sudo ./pinephone-usb-gadget.sh setup sudo ./pinephone-usb-gadget.sh start
(11-12-2020, 05:46 PM)ak42 Wrote: Regarding protonmail, I have successfully rebuilt the protonmaill bridge in nogui mode, and was able to get my protonmail email from geary (I built it myself from geary's github, the one pre installed segfaults...)
Are you running protonmail bridge cli each time before opening geary, or do you have it setup to auto start on boot?
