ARM Version of libttspico-utils?
I am trying to port the Kalliope voice assistant to Mobian as Kalliope works on Debian x86. The only issue I have found so far is I cannot find an ARM version of the pico TTS (text to speech) utility library. Before I try and build it myself I figured I would ask if anyone knows of a prebuilt ARM version. Any distros version would help.
TIA
LF
Figured it out. Add the non-free repository to the deb.debian.org bullseye apt repository entry
"deb http://deb.debian.org/debian bullseye main non-free"
sudo apt-get update
sudo apt-get install ......
