HDMI via USB Hub
PmOS edition with convergence hub - mouse working, keyboard working, charging is OK .... HDMI not.
Have anybody some ideas ?
Wysłane z iPhone za pomocą Tapatalk
There is a issue on gitlab about this.
Sent from my iPhone using Tapatalk
Could you share the link ?
If you want to try hdmi now I suggest you flash megi´s excellent multi-boot image to a sd card. I find that megi´s own kernel has worked best in regard to hdmi out.
"- is there already a tool for overclocking it desperately?"
https://gitlab.com/postmarketOS/pmaports/-/issues/735
(09-23-2020, 01:22 AM)murak Wrote: If you want to try hdmi now I suggest you flash megi´s excellent multi-boot image to a sd card. I find that megi´s own kernel has worked best in regard to hdmi out.
Indeed, for pmOS Gnome and Phosh at least however without charging in parallel.
Keep progressing. BTW in Phosh you cannot move app window between displays.
Thanks for this tip !
(09-22-2020, 12:57 PM)skaf2007 Wrote: PmOS edition with convergence hub - mouse working, keyboard working, charging is OK .... HDMI not.
How did you get the mouse and keyboard working?
Well, they work out of the box, just connecting to the USB ports. However I could expect that modern, „gaming”, iluminated devices can face problem with power efficiency.
Official stable pmOS just got new kernel and HDMI works out of the box ! now it’s time for the next step - how to be able to work with apps on the second display Smile
Does somebody manage to do it with Phosh ?
„Windows” Key + mouse are doing the job
