change temp & mesurements on calendar
Running SFOS on my device, still no sim card, yet
In setting my location for the weather, in the USA, it is in celsius & cm/mm
I believe I've looked through all of the settings, and have not found a way to change them
I eventually found the answer buried deep in another setting section. don't recall where at the moment
(09-23-2020, 03:49 PM)RodneyMyers Wrote: I eventually found the answer buried deep in another setting section. don't recall where at the moment
Maybe at the bottom of the settings there a section for app configurations
Correct.
settings, weather. inside that app, It is changeble
Correct.
-- You, sir, are a gentleman and a scholar.  THANK YOU.
