any chance of 32bit armhf support?
Any tips on being able to get armhf libraries to download via apt-get?
If I add the architecture, it still can't locate them
Thanks!
It seems you posted this in the wrong subsection? This bit of the forum is about postmarketOS, which doesn't use apt-get.
(08-22-2020, 03:31 AM)PureTryOut Wrote: It seems you posted this in the wrong subsection? This bit of the forum is about postmarketOS, which doesn't use apt-get.
Opps, you're right. It's the apk thing in PmOS.
Do you plan on adding 32bit support at any point?
You can always set up a nice little chroot, and if you set up the environment variables, you can even run X11 applications through it. I've done that before.
Alpine isn't multilib, if you really need a 32bit userspace for an application, consider containerizing it or running it in a chroot
  fwupd support user641 2 5,064 03-26-2022, 06:50 AM
Last Post: user641
  The end of 3G and VoLTE support jmorris 2 6,173 10-25-2021, 07:37 AM
Last Post: wibble
