32 bit apps supported?
I was wondering if pureos or mobian will support 32 bit apps in the future?
Thanks!
(08-15-2020, 06:42 AM)pcdoodle Wrote: I was wondering if pureos or mobian will support 32 bit apps in the future?
Thanks!
What are you hoping to run that doesn't have a 64bit version available?
Thanks!
The toolchain I use (Xojo) only supports building 32 bit ArmV7 apps ATM.
Is it hard to add support?
I suggest you file an enhancement request - the worst they can say is WONTFIX and then at least you know!
I think it depends on what level of support you're looking for. As I understand it (and I may not!) the bare minimum is a kernel that supports 32 bit ('Userspace binary formats ---> Kernel support for 32-bit EL0' in menuconfig). That's the easy part, but should be enough for static executables. The problem comes with libraries etc. as AFAIK there isn't an arm equivalent of the 32 bit compatibility libraries we have for x86/x86_64. If Debian supports that then Mobian probably will, and likewise for PmOS and Alpine linux.
You can try running your app through QEMU. It does have support for armhf
The xojo forums has a thread tracking the issue; Looks like it will come soon, there's also a post in the thread that mentions a wrapper workaround that might work for you.
https://forum.xojo.com/t/arm64-its-time/52793
(08-20-2020, 08:29 AM)fins Wrote: The xojo forums has a thread tracking the issue; Looks like it will come soon, there's also a post in the thread that mentions a wrapper workaround that might work for you.
Thanks for the tips. I saw that too.
Problem is the adding the armhf architecture only causes apt-get to error when trying to find libraries.
  New Install, apps start but don't show up on screen?! RT3 2 3,602 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,614 01-15-2025, 08:08 PM
  Keyboard not popping up on QT apps 3x5co 1 3,438 02-08-2024, 11:45 PM
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 2,797 07-17-2022, 10:34 AM
Last Post: 3x5co
  Using lat/lon in GPS/GNSS apps and Messaging biketool 6 9,518 05-04-2022, 11:45 AM
Last Post: wibble
  Apps and SD Card biketool 2 4,771 03-06-2022, 09:47 AM
  Reskinning Apps for Mobile biketool 6 9,208 12-05-2021, 02:30 PM
  no access to webdav files (for some apps) jsch 0 2,962 11-13-2021, 09:46 AM
Last Post: jsch
  Sizing apps to fit to screen county93 4 7,089 10-23-2021, 11:36 PM
Last Post: bcnaz
  What causes the long delays which switching or starting apps? motox6 10 16,446 10-17-2021, 05:58 AM
Last Post: vortex
