Build issue on Windows 10
I'm on Windows 10, I managed to launch the Cmake command with OpenOCD mode.
Then, when I launch "make" I have errors :
arm-none-eabi-gcc: error: BOARD_PCA10040: No such file or directory
arm-none-eabi-gcc: error: CONFIG_GPIO_AS_PINRESET: No such file or directory
arm-none-eabi-gcc: error: DEBUG: No such file or directory
arm-none-eabi-gcc: error: DEBUG_NRF_USER: No such file or directory
arm-none-eabi-gcc: error: FREERTOS: No such file or directory
arm-none-eabi-gcc: error: NIMBLE_CFG_CONTROLLER: No such file or directory
arm-none-eabi-gcc: error: NRF52: No such file or directory
arm-none-eabi-gcc: error: NRF52832: No such file or directory
arm-none-eabi-gcc: error: NRF52832_XXAA: No such file or directory
arm-none-eabi-gcc: error: NRF52_PAN_12: No such file or directory
arm-none-eabi-gcc: error: NRF52_PAN_15: No such file or directory
arm-none-eabi-gcc: error: NRF52_PAN_20: No such file or directory
arm-none-eabi-gcc: error: NRF52_PAN_31: No such file or directory
arm-none-eabi-gcc: error: NRF52_PAN_36: No such file or directory
arm-none-eabi-gcc: error: NRF52_PAN_51: No such file or directory
arm-none-eabi-gcc: error: NRF52_PAN_54: No such file or directory
arm-none-eabi-gcc: error: NRF52_PAN_55: No such file or directory
arm-none-eabi-gcc: error: NRF52_PAN_58: No such file or directory
arm-none-eabi-gcc: error: NRF52_PAN_64: No such file or directory
arm-none-eabi-gcc: error: NRF52_PAN_74: No such file or directory
arm-none-eabi-gcc: error: OS_CPUTIME_FREQ: No such file or directory
arm-none-eabi-gcc: error: __HEAP_SIZE=8192: No such file or directory
arm-none-eabi-gcc: error: __STACK_SIZE=8192: No such file or directory
arm-none-eabi-gcc: error: unrecognized command line option '--defsym'
So I tried to use nrf Connect to use DFU, but I have not the possibility to use it on the application (I'm with a Glaxy S8 and it is not poossible with an IPhone too)
I have no Raspberry Pi available right now.
What is the solution to flash it with my computer ?
Thank you !
  Article: Build and Flash Rust+Mynewt Firmware for PineTime Smart Watch lupyuen 8 17,697 01-18-2020, 01:01 AM
Last Post: clover
