08-10-2020, 05:55 AM
Hello and what the pinephone is the sim card and compatible to work in France?
Thank you so much
Thank you so much
Smicard
Thank you so much
08-10-2020, 10:27 AM
Dans le Wiki tu as les APN pour la France https://wiki.pine64.org/index.php?title=...N_Settings
Je n'ai pas encore le mien mais j'ai vu des retour français ( per exemple https://linuxfr.org/users/a-wai/journaux...-pinephone ) Et d'autre sur le forum donc il devrait fonctionner ![]() In the Wiki you have the APN for France https://wiki.pine64.org/index.php?title=...N_Settings I don't have mine yet but I have seen some French returns (for example https://linuxfr.org/users/a-wai/journaux...-pinephone ) And others on the forum so it should work in France
