Notification LED only red works
I have PinePhone CE (no CC fix version).
I installed factory test image and discovered, that only strong and weak red light works.
I tried this guide: https://wiki.postmarketos.org/wiki/PINE6...e)#RGB_Led
Directory structure was different. Only red was working.
Is this hardware issue or software issue?
There is only one led, but, it can show all the described colors, so most likely if it does show the red color, the led is ok.
It is dependent on the software for any function, or color.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Display doesn't works leirunh 1 3,989 04-30-2021, 05:02 AM
Last Post: marcih
