Included screen protector's protection is hard to notice
Even though I received my PinePhone Braveheart months ago (albeit not using it as my daily driver), I just noticed that there are actually 2 screen protectors layered. The top one should be removed because it gets scratched very fast. Hence I thought the screen protector was of poor quality where as it does not seem to be actually. This info could be made clearer somewhere (in the box and/or in the store ?). Idea
My braveheart had a sticker on the top layer of film that said to remove it after application - presumably of the protector underneath. I peeled carefully since someone mentioned the protector underneath came off with it when they tried, and didn't have any problems.
The Braveheart batch had plastic screen protectors applied, underneath the protector is the glass panel.
Plastic screen protectors scratch easily - if you want reasonable protection, try the new glass screen protectors sold in the PINE store. You could also try iPhone XS Max protectors, but in my experience they suffer from the 'halo effect.'
I don't know if future models will continue to include the plastic protector. Perhaps direct this question to @Luke ?
I'm actually kind of curious about this. I have the UBPorts CE pinephone and my screen protector scratches really easily, like... my *fingers* scratch it.
Did my phone come with a plastic one or with the glass one that's in the parts store?
@stemplet Definitely plastic; plastic screen protectors scratch easily.
If your fingers are scratching glass, you've either got big problems, or really big advantages.
The screen protector comes with its own protector which you are supposed to remove before using the phone.
I kept mine on and managed to find a good folio case. My "protector's protector" is still largely intact with only very minor scratches. Only if it becomes bad, I will use the real protector underneath.
  Screen dying already? marcih 156 292,662 06-12-2025, 06:18 AM
Last Post: mikeb
  Screen Replacement Instructions erikkugel 5 11,317 02-24-2025, 06:55 AM
Last Post: anonymous
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 1,927 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 6,359 10-12-2023, 01:03 PM
Last Post: robthebold
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 8,250 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 4,454 07-03-2022, 06:27 AM
Last Post: Avisando
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 8,770 03-08-2022, 12:25 PM
Last Post: jopple
  How hard to replace screen? Zebulon Walton 28 49,705 01-18-2022, 12:21 AM
Last Post: henrythemouse
  pinephone screen Uturn 2 5,007 01-14-2022, 01:15 AM
Last Post: Uturn
  Screen replacement Csanderson0313 4 7,006 01-10-2022, 09:26 PM
Last Post: Csanderson0313
